Transmission Fluid Charges according to Consumer Reports
#11
"The Transmission Flush: If you follow the recommended maintenance intervals, doing a scheduled flush is fine. But don't start doing flushes if you've ignored the intervals. The grime and gunk that collects in unchanged fluid becomes the friction material in an aging clutch pack. Replacing the fluid may cause the transmission to fail"
I believe this has been disproved by many. I also wonder why the grime and gunk that becomes friction material for the aging clutch pack doesn't also become friction material where you don't particularly want friction material?
I have seen many supposed facts quoted in Consumer Reports that were just wrong. They do a lot of good but they just cannot be experts in everything.
I would do a filter and pan drop every 40k miles or so. And Valvoline Maxlife ATF works very well in these. Its full synthetic also. The factory fluid really is not full synthetic and has been surpassed by many import atf's since the fluid spec is from the early 90's. The original fluid was and is nothing more than dexron III with no red dye, and a few long life additives.
#12
I went ahead and changed the fluid and filter yesterday. At 22,000 miles fluid was dark amber. But not black. Some minimal dark sediment on the bottom of the pan. No metal "hairs" at all on magnets. Also cracked open the filter. Nothing in there. Completely clean.
I have used Pentosin ATF1 for last 3 changes. It's a bit more expensive than the Vaico fluid ECS supplies with their kit. But felt it was worth keeping the fluid consistent.
Refill took just about 6 liters. I changed out the drain plugs this time as well.
Should be good for another 30k....we hope.
Thanks again for all the responses.
#13
When you changed the fluid, did you just replace the amount you got out, or did you do the whole thing with running it while filling? I have to admit that I'm queasy running the car on jackstands, though I suppose its not really any different than being under the car on jackstands--but I never have all wheels in the air then.
#14
Good luck.
#16
It took just under 6 liters to refill. Pentosin is available in a 5 liter jug that makes it real easy. And less messy than fussing with individual bottles. . If you have a Harbor Freight nearby buy one of their fluid transfer pumps. They're about $7, and pump high volume. I've used it for last two changes. Works well. I believe the ECS Tuning Kit comes with 6 liters. Not sure of others. Good luck!
#18
I'm about to do a transmission fluid and filter change on my '00 A6 Avant at 158,000miles. Then I read this on Page 55 of the March 2016 issue of Consumers Report , just delivered. Quote:
Yikes.
I guess the key is they qualify their statement by saying a fluid change is only detrimental if you've previously ignored fluid changes.
But this still goes against everything I have read from experts on the topic. I.e. Kansas City TDI (CoolAir VW) who has always been a big proponent of fluid changes.
I guess the debate continues..
Yikes.
Proper fluid replacement never hurts.
This myth comes from people who "notice" a little problem (or more) and them change the fluid and when the transmission dies they blame the fluid change instead of the real problem.
mcmorariu
12-29-2013 11:44 AM
mikesd1980
07-02-2008 07:09 PM
Jon-1.8t
01-18-2006 09:57 AM
