Transmission Slipping?? Help Please!
Old 02-26-2011, 04:21 PM
djhellbent's Avatar
Default Transmission Slipping?? Help Please!
So here's my problem.
1996 Audi A6 Quattro (Automatic Transmission)
The other day, I was driving through deep snow, and drifts along the road, so the drive was pretty bumpy and hard on the car.
The next day I went to drive my car, and realized that now when I come to a complete stop, when I drive the car has to get up to about 4.5k rpm before it will Kick in and drive. Before this, my car has never had a problem with transmission slippage.
The symptoms are:
- Coming from a complete stop, the car has to rev up to about 4.5k rpm before it will engage (I noticed after it engages that my all wheel drive will also kick in) Once the car is going it will continue to go and shift through gears
- While driving, the shifting between gears is unnaturally hard, as is the downshifting
- When the problem first occurred, if I was in reverse and put it to drive, my car would stall out (Similar to releasing the clutch too soon on a manual) Note: This has not been a problem the last time I drove the car
- Reverse works perfectly fine
- My instrument cluster (PRND321) - while I'm driving will flip between D N and R, I originally thought this was a loose wire, but may be useful for diagnosing
- The car drives fine if I manually shift between gears 1 thru 3
The VAG-COM reported:
00753 - Electrical Connection to Wheel Speed Sensor
35-10 - - - Intermittent
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Old 02-26-2011, 05:45 PM
Tech Guru
4Driver4's Avatar
You want the C4 forum for your 96.
You should check fluid and pull codes, but forward clutch is probably shot. Start shopping for a used trans.
Old 02-26-2011, 06:05 PM
Duchateau's Avatar
My car did the same thing about 3 months ago. I ended up taking it to the dealership and the fluid was really low and gross looking. Because I waited so long to take it in the transmission was shot and I ended up purchasing a rebuilt one... Long story show my guess would have something to do with low fluid levels
ZCD2.7T
S4 (B8 Platform) Discussion
17
03-19-2012 09:38 AM
djhellbent
Audi 100 / A6 (C4 Platform)
03-05-2011 08:00 PM
AveMech1
08-30-2008 01:22 PM
4Driver4
VAG-COM Discussion
11
05-22-2007 03:04 AM
Dennis H.
09-28-2001 12:50 PM
Quick Reply: Transmission Slipping?? Help Please!
