I could use some advice with a potential steering issue.
Old 03-11-2012, 07:18 PM
S6AVANTDRIVER's Avatar
Default I could use some advice with a potential steering issue.
Whenever my car is sitting still and I turn the wheel left or right, I can hear a popping noise in the steering. It doesn't do it when the cars moving. Has anyone had this problem or know what it is? Thanks in advance!
-Ben
Old 03-12-2012, 03:59 AM
5v/cyl's Avatar
Have someone turn the wheel while you lay under the front and listen/feel for the popping. Should be able to localize the noise to a certain area. Could be TRE, control arm, or sway bar link/bushing. If none of those then you need to dig a bit deeper and check steering rack joints/mounts and worst case steering rack itself.
Old 03-12-2012, 05:32 AM
Thank you, I'll try that today and see what I can figure out. Thanks again.
Old 03-14-2012, 03:57 PM
Default I Found the Issue!
The front control arms need replaced. From what I can understand, there are four on each front wheel. To replace all of these is going to cost me around $1000. Is that about right? too high? too low? Thanks guys!
Old 03-14-2012, 05:07 PM
5v/cyl's Avatar
All of them??? Usually you will just replace the bad ones.
If your DIY then the cost of a complete kit to do everything is around $500-$600 for good aftermarket Meyle or Febi ones. OEM will be pricey. Lowers are expensive. Uppers are much cheaper.
If your having it done then $1000 would be about right for all of them(pinch bolt can be PITA), but again usually just do the bad one(s).
Old 03-14-2012, 05:56 PM
SloopJohnB@mac.com's Avatar
If you do it yourself they're something like $135 each from the dealer....a couple bucks for a couple pinch bolts.
Not particularly tough with air tools. Lots of videos online on how to dø it.
Lemfoerder is a ZF company that also provides OEM UCAs. Look around, shop around.
Yang L
Q7 MKII Discussion
09-28-2020 06:21 AM
garysaunders85
02-05-2019 09:39 PM
mattarios2
05-04-2006 01:28 PM
A4NJ01
02-27-2005 01:09 PM
JeffK (B6S4)
07-02-2002 03:58 AM
Quick Reply: I could use some advice with a potential steering issue.
