Vibration when braking... - AudiWorld Forums
Old 02-05-2014, 12:43 PM   #1
tester123's Avatar
Default Vibration when braking...
Since it looks like we live Siberia nowadays, haven't had the opportunity to open up and find out why there is significant vibration when braking. It seems to be coming from front passenger side. A month ago, car was sitting for a week or two and when driving, brakes made that "scratchy" noise.. typical as rust builds a layer on rotors... usually goes away after few hard brakes but, this vibration hasn't gone away. There is no visual indication of rust on rotors and brakes are quite now except this vibration.
Control arm? Rotor warped? Bearing? I was told by dealer that bearing is bad but this was 20k miles ago. No obvious grinding noise or excessive play sideways (not any I noticed at least when it was on jacks)... Don't know for sure if it really needs to be changed but was going to anyway when weather warms up.
Any ideas?
tester123 is online now   Reply With Quote
Old 02-05-2014, 02:12 PM   #2
tenspeed's Avatar
Check out this site about vibrations under braking
http://www.stoptech.com/technical-su...nd-other-myths
To check the wheel bearing, raise the wheel and spin it while holding onto the spring. If it's bad bearings, you can feel them crunching in the races.
tenspeed is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Allroad "double spoke" wheels/vibration Tahoesilvers4 Audi allroad 3 09-29-2015 08:05 AM
:: ECS Tuning :: B7 A4 2.0T ECS RA4 Conversion Clutch Kits ECS Tuning-Audi A4 (B7 Platform) Discussion 0 09-24-2015 01:06 PM
Vibrating and leaking bpatrick99 A6 / S6 (C5 Platform) Discussion 7 09-17-2015 02:58 PM
Strange Tire/Wheel Issue Acuransx A6 (C7 Platform) Discussion 3 09-14-2015 01:43 PM
3.0 tfsi Caja engine vibration Yatta A6 / S6 (C6 Platform) Discussion 0 09-09-2015 12:52 AM
Tags
42, audi, brake, issue, r8, vibration
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
