Went to mechanic--the code P0442 he says he pulled the code for a bad cat. Any ideas. Can I - AudiWorld Forums
Old 06-20-2008, 02:40 PM   #1
Default Went to mechanic--the code P0442 he says he pulled the code for a bad cat. Any ideas. Can I
get an after market one maybe a more performance one and have my mechanic put it in?? My car is over the 8/80 warranty so I am knid of stuck here. I am aware this can be a costly repair.
TIA
audiquattroduo is offline   Reply With Quote
Old 06-20-2008, 02:48 PM   #2
Tech Guru
4Driver4's Avatar
Default The code for a bad cat is just a code. You need to get to the root of the problem before...
...spending any money. First off, what engine and model year?
4Driver4 is offline   Reply With Quote
Old 06-20-2008, 02:57 PM   #3
It is a 2000 A6 4.2. I replaced the O2 sensor 8-4-2007917819 bank 2 secondary air injection)
Old 06-20-2008, 03:00 PM   #4
Tech Guru
4Driver4's Avatar
Ugh. OEM O2 sensor? You're probably looking at a cat then. :-(
Old 06-20-2008, 03:06 PM   #5
Default That is what he told me.I am going to pick-up the car tomorrow and weigh my options.I can drive...
the car the way it is ---- no loss of power or rattling noise.
Old 06-20-2008, 08:08 PM   #6
Member
Default Sorry, but I had to fvcking LOL : ) What are the chances that two green 4.2's
would suddenly have bad cats? And amusingly enough, I received my emissions notice today :P
audikillsbmw is offline   Reply With Quote
Old 06-20-2008, 08:29 PM   #7
Junior Member
Default My dads old 4.2 had a bad cat code from 2003 until it commited suicide in 2007. I really wouldn't wo
rry about it.
Auditude2.0T: BT PWR is offline   Reply With Quote
Old 06-20-2008, 09:38 PM   #8
Thanks.I think I am going to get two magnaflow cats and put them on.
Old 06-21-2008, 03:15 AM   #9
How did it pass emissions?
MA_2.7t is offline   Reply With Quote
Old 06-21-2008, 04:53 AM   #10
Member
Default BAD CAT from P0442 code only??? No way!!!
P0442 code is a small evap leak, like a gas cap, vacuum line etc. Did you have any other codes like P0420? If not, run away as fast as you can from that mechanic.
jasaab is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
What to do about P1411?? spaniel1287 A4 (B5 Platform) Discussion 16 09-10-2015 02:02 PM
First Experience with Audi Dealer Service Dept. the_duke A8 / S8 (D3 Platform) Discussion 6 09-10-2015 09:02 AM
Best way to launch my RS6? LaserSVT RS 6 Discussion 2 09-06-2015 07:54 PM
Limp Mode 2.7 Tip cameltrophyallroad Audi allroad 4 09-04-2015 05:40 PM
Mechatronic and Sport Differential issues wjhpilot S4 (B8 Platform) Discussion 0 09-04-2015 01:43 PM
Tags
06, 1998, 2002, 2006, 2007, chevy, code, f250, ford, miata, p0442, po442, s80, suburban, volvo
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
