whats the advantage of biger wheels, from 16 to 18 for example - AudiWorld Forums
Old 12-09-2006, 01:14 AM   #1
alezome is offline   Reply With Quote
Old 12-09-2006, 01:36 AM   #2
iProDrive's Avatar
Default From personal experience from 16" to 17" was a better feel for the road...
I am considering going 18" for summer 07'. My cons are its a bumpy-er ride and the pot holes will be my worst enemy.
16" to 18" would also improve the cars looks IMHO.
Try a <a href="http://search.audiworld.com/">AW Search</a> in the C5 A6 forum for "bigger rims".
iProDrive is offline   Reply With Quote
Old 12-09-2006, 05:13 AM   #3
Tech Guru
4Driver4's Avatar
Default For most folks, the answer is Bling. For most the wheels are actually a disadvantage.
True a larger wheel can sometimes give better road feel and enhance handling, but larger wheels are almost always heavier wheels. Heavier wheels add unsprung weight and unsprung weight degrades accelleration, braking and handling.
Like everything else, wheel size is compromise; you need to find a wheel that is large and wide enough to maximize handling, but light enough not to destroy handing. The other problem is that lighter and stronger are usually more expensive, so most larger diameter wheels tend to be heavier.
IMHO, a light, strong 17 x 8 is the optimal size for the C5. People go larger for a cool look and damage the drivability. Then they install there winter tires on stock wheels and "rediscover" their cars.
4Driver4 is offline   Reply With Quote
Old 12-09-2006, 05:55 AM   #4
Chief Cook and Bottle Washer
Kris Hansen's Avatar
Default Not to mention, larger wheels, even lighter ones, slow you down..
Because the weight of the wheel is farther out from the hub. I noticed a difference going from my 17s to my 16 steelies. =)
Kris Hansen is offline   Reply With Quote
Old 12-09-2006, 06:09 AM   #5
Default 16's for comfort. 17's for best combination of looks and handling, 18+ personal style
The larger the wheel as 4Driver4 stated below the more you have to spend to get a lighter one. You will also pay more for tires and have much shorter tread life. You also have a much higher risk of bending them at 18+. I agree that a good 17 x 8 with 235/45/17's is the best all round setup.
Murph is offline   Reply With Quote
Old 12-09-2006, 06:24 AM   #6
Fear the Miata!
Press's Avatar
Default whatever you decide make sure you get a quality wheel....if you can afford to go oem that's the best
i have two sets of 17's and one set of 18's and they serve different purposes.....one set of 17's are snows, one set i use on the track, and my 18's are oem rs6 wheels that have summer only rubber on them....weight is important, but these car are heavy to begin with so a few extra pounds make little difference on the street....if you're going to track the car then that's a different story....8^)
Press is offline   Reply With Quote
Old 12-09-2006, 08:09 AM   #7
New Member
Default Re:larger wheels also allow room for larger brake rotors and calipers,
crisper turn in due to smaller side walls and a generally a wider "footprint".
EdCz is offline   Reply With Quote
Old 12-09-2006, 08:23 AM   #8
Default More "road feel", larger contact patch, firmer ride, better looks, allows for larger brakes, sharper
turn in.
The cons are obvious....firmer ride, more $$$, and more prone to wheel damage.
Recently, the group mentallity on this board has convinced themselves that 17's are the way to go, keep in mind they are old farts....loveable, but old farts nonetheless. : )
Cargasm2.7 is offline   Reply With Quote
Old 12-09-2006, 08:35 AM   #9
Fear the Miata!
Press's Avatar
Default who are you calling old?....8^)
btw....i like my 18's....
Old 12-09-2006, 08:47 AM   #10
Default Actually, I think your set up is ideal. 18's for summer, 17's for snow, 17's for the track. If...
money were no object, 18's would be better for the track. However, if I end up buying track wheels, they too will be 17's. The cost factor and more readily available light weight wheels makes it a no-brainer.
Thread Thread Starter Forum Replies Last Post
Audi Q7 Winter setup OEM S-line 20" Bridgestone Blizzak 275/45R20 rayjr13 Parts For Sale 10 04-12-2016 05:43 PM
New Q7 2015 TDI slight shimmy dealer calls it road feedback? Quetzal Wheels & Tires Discussion 3 09-23-2015 08:50 PM
Audi A8 20x9 Rohana RF1 Brushed Titanium (Rotary Forged) wheels cm09578 Parts For Sale 6 09-22-2015 07:38 AM
Need Help with Winter Tire/Wheel set at Tirerack mkirkpatrick Wheels & Tires Discussion 2 09-03-2015 09:31 AM
Tags
1, 16, 18, adavantage, advantage, bigger, cars, compared, inch, rims, wheels
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
