Working fob programming instructions 1999 A6 - AudiWorld Forums
Old 02-24-2014, 04:30 PM   #1
Default Working fob programming instructions 1999 A6
I am posting this because I found hundreds of different instructional posts about this and none of them were correct. Here is a functional guide.
I bought these keys on ebay for less than 40$
http://www.ebay.com/itm/2-New-Uncut-Flip-Key-Pair-Remote-Keyless-Entry-Fob-Clicker-For-4D0837231E-/111196866484?pt=Motors_Car_Truck_Parts_Accessories&hash=item19e3d987b4&vxp=mtr
2 New Uncut Flip Key Pair Remote Keyless Entry Fob Clicker For 4D0837231E
I found many posts on many forums stating that the trunk release wouldn't work on my car. Incorrect. Here is my programming guide.
The first thing that needs to be done is temporarily number the fobs. This is because they are tied to the seat memory. (if you open with fob 1 and the 1 position is programmed in the seat computer, the seat goes to p1. likewise for fob2/key2)
You really need two keys to do this but I didn't want to cut the blades before testing the keyless so I removed the door panel and found the two wires for lock and unlock. They are the middle two wires on the plug going to the lock assembly. (Green/blue stripe and brown/yellow stripe) One being lock and the other unlock. You just need a grounded wire and to remove that plug and jump. This allows you to leave your working key in the ignition if you only have one.
Here are the actual steps
1:With the doors unlocked, turn the ignition to run (not start)
2:lock the doors with the second key (or grounding wire) note: you do not need to hold in the lock position. Just locking it with the key in puts you in programming mode.
3: take the fob labeled 1 and press lock once (Lights will blink)
4:Wait 10 seconds and unlock then lock the doors
5:Press unlock on fob 1 (doors should unlock)
6:Open door remove key
To program fob two follow the exact procedure above EXCEPT!!!
Modified step 3:take the fob labeled 2 and press lock twice (Lights will blink 2 times)
You can have up to 4 fobs. There are 4 positions in the computer so fob three would be 3 presses and 4 would be 4. (note: 5 presses erases that fob from memory)
sounddude is offline   Reply With Quote
Old 02-24-2014, 05:24 PM   #2
jcman's Avatar
Default FYI
There is another way to program or reprogram FOB's in vagcom too with extra features.
Aside from having the key cut the RFID chip needs to be adapted to the immobilizer and that is done at the dealership unless you take the existing RFID chip capsule out and place it in the new FOB.
jcman is offline   Reply With Quote
Old 02-24-2014, 05:25 PM   #3
jcman's Avatar
BTW, the RFID chip has nothing to do with the FOB remote functions.
Old 02-24-2014, 06:28 PM   #4
Yeah, I read about the VAGCOM ways but I don't have a VAG. I don't really see the need. I paid $50 for my code scanner and it tells me why my CEL is on just the same. The only thing I can't do with mine is recode modules. To me all that means is, if I need a replacement ECU, it has to come from the same year/eng/trans combo. I know you guys are all about it but I can do anything with mine that I will ever need to do. If I had a newer CANBUS car the VAGCOM would be a lot more desirable.
1999 A6 doesn't have an immobilizer. I'm not sure 2000 did either. (I think 2000 was the split year for immobilizer) Here is some great data on cluster, IMM, and basically anything that has to do with the cluster.
http://www.audizine.com/forum/showth...ibility-issues
Old 02-24-2014, 06:42 PM   #5
jcman's Avatar
I see, the difference is that vagcom can recode the convenience module to do other functions like no beep on locking or roll the windows up or down with FOB including the sun-roof and to reprogram FOB's.
You're right with the cluster IMO year but the key/fob has to communicate to allow a secured start, I have more info on that to share so bear with me unless someone else has it now.
Old 02-24-2014, 06:48 PM   #6
Yes and those things would be nice. When I bought my scanner I was just trying to get a $1000 A6 back on the road. Now I'm rollin with key fobs.
I do not think that is correct. Until now, I never had a key fob and my key is not one with the W on it. I have no RFID chip. I called my locksmith to verify. It's just a plain HAA blade and, it's working.
Old 02-24-2014, 07:07 PM   #7
jcman's Avatar
Yep 99 and some 2000's don't have the RFID chip, my 2001 old car and 04 current do.
But anyways I do have this interesting link for you...and no I'm not trying to sell you on vagcom, you will see what I mean with that comment.
http://wiki.ross-tech.com/wiki/index.php/Immobilizer
Old 02-24-2014, 07:34 PM   #8
Great info for this thread.
The Ross link has been invaluable to me.
I've seen some conflicting information on Immobilizer programming with VAG during my research. Is there a functioning step by step?
Old 02-25-2014, 04:29 PM   #9
jcman's Avatar
What conflicting info are you concerned about?
Unless your considering remote start or a new cluster.
Old 02-26-2014, 09:23 AM   #10
I just thought that since this thread is about fobs and IMO, maybe (even though I don't need them for my car) it would be good to have working instructions for both VAG programming of keys as well as coding the IMO with VAGCOM. I'm good, my car works great and I have no need for IMO instructions at this time.
Thread Thread Starter Forum Replies Last Post
Chcicago Region SCCA Track Day @ Autobahn Country Club Joliet, IL Sept. 13, 2015 old-dog Chicago Discussion 4 11-28-2016 05:12 AM
Adding bluetooth audio to my new (to me) 2009 Cabriolet with Bose xkahn A4 Cabriolet (B6 Platform) Discussion 3 08-07-2016 06:38 PM
DIY Remote start Q5 IntheQ5 Q5/SQ5 MKI (8R) Discussion 27 06-09-2016 01:37 PM
96 a4 fob questions Randy Castro Audio, Video and Security Discussion 1 09-13-2015 04:09 PM
New Member and Fan/Trunk Question raiderrider A8 / S8 (D3 Platform) Discussion 12 09-08-2015 06:46 AM
Tags
1998, 28, a4, audi, fob, key, programming, remote, swiychblade
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
