'06 A6 Avant Navigation install?
My '06 came w/o navigation. I'm starting to see these cars appear in junkyards and wonder what's involved in installing factory navigation. Will installing the Navigation unit w/proper DVD do it. Of course an optic cable would be needed to tie it into the system. Or, is there more wiring & VAG-Com coding involved?
TIA
TIA
TIA
TIA
Essentially you need the DVD drive, the GPS antenna and appropriate wiring, and finally the actual DVD
TIA
TIA
I did this to my '06 Avant. All I did was install the dvd player and plug in a cheap aftermarket gps antenna from amazon. The plug was already available. You simply need to remove plug from the cable. That plug caps off the fiber optic cable and tells system that nav is not installed.
The harness kit was more expensive, I didn't want to tear apart the interior trim on my wagon, and I didn't want to risk having to replace the fin-antenna if it had leaked.
No issues whatsoever with reception. It seems to always have reception. I've never had a delay finding my position. I just tucked that antenna in the trim with the dvd player.
boozeedoo
12-02-2009 10:08 AM
samsco
08-10-2007 12:20 AM
caveatesq
10-26-2003 04:59 PM
