07 a6 3.2l 160km. crank no start. please helpp!!!
#11
its not the crank sensor because the rpm gauge went up a bit meant that those are fine, what Im not hearing it the coils ticking.... turn the ignition on, unplug the plug from the coil, you don't need to remove the coil then see it there is power in any of the leads, usually you just need to check the fat wires, read with a line but just check all if there is no 12v or 11v or what every charge your battery has left, look in the fuse box on the right of the DASH you will see ignition and injector fused check them.... if they're good spray some carburetor cleaner into the intake and see if it starts or the engine ignite, you are missing gas or spark, access control is good else the steering wouldn't unlock and the engine would not crank, just check all the fuses on the right they responsible for the engine management...
First thing ill do is check all the fuses like you recomended because that will be quick and easy, i actually just changed cigerete lighter fuse today. I dont have a volt meter but ill get my hands on one asap and check the coils and wires. Thanks again
#13
scan results+ update
hello all. so i got my rosstech cable and scanned. i got 7 faults for engine that keep showing up. i got a few others (media players not detected, airbag limit too high etc.) but im not too concerned about those because i know what those problems are and highly doubt they can be the reason for my issues.
here are my engine faults
Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
Part No SW: 4F2 910 559 C HW: 4F1 907 559 E
Component: 3.2l V6 FSI 0070
Revision: --H19--- Serial number:
Coding: 010D0109190F0120
Shop #: WSC 90378 999 100058
VCID: 2C5770768F25605EF2-8078
7 Faults Found:
001378 - System Voltage
P0562 - 007 - Too Low - Intermittent
Freeze Frame:
Fault Status: 00000010
Fault Priority: 2
Fault Frequency: 20
Reset counter: 27
Mileage: 161100 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Mass Air / Rev.: 0.0 mg/str
Temperature: 33.0°C
Engine Off
Load: 0.0 %
Voltage: 0.61 V
001671 - ECM Power Relay Control Circuit
P0687 - 007 - Short to Plus - Intermittent
Freeze Frame:
Fault Priority: 4
Fault Frequency: 8
Reset counter: 27
Mileage: 161100 km
Time Indication: 0
Date: 2006.03.15
Time: 12:01:27
Freeze Frame:
RPM: 0 /min
Temperature: 61.5°C
Engine Off
Load: 0.0 %
Voltage: 0.61 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 4
Reset counter: 4
Mileage: 161100 km
Time Indication: 0
Date: 2006.03.15
Time: 12:03:41
Freeze Frame:
RPM: 832 /min
Mass Air / Rev.: 92.7 mg/str
Temperature: 93.0°C
Idle
Load: 14.9 %
Speed: 0.0 km/h
008304 - Intake Manifold Tuning Valve (Bank 1)
P2070 - 006 - Stuck Open
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 29
Reset counter: 40
Mileage: 161737 km
Time Indication: 0
Date: 2016.04.09
Time: 21:58:22
Freeze Frame:
RPM: 1344 /min
Mass Air / Rev.: 316.1 mg/str
Temperature: 30.0°C
Idle
Absolute Pres.: 712.9 mbar
Speed: 0.0 km/h
005634 - Power Supply Terminal 30
P1602 - 008 - Voltage too Low - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 4
Mileage: 161999 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Temperature: 13.5°C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
012410 - Air Intake System
P307A - 009 - Flow too Low
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 12
Reset counter: 40
Mileage: 164052 km
Time Indication: 0
Date: 2016.04.28
Time: 15:10:20
Freeze Frame:
RPM: 1184 /min
Temperature: 88.5°C
Overrun
Voltage: 13.26 V
Speed: 48.0 km/h
000104 - MAP/MAF Throttle Position Correlation
P0068 - 007 - - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 5
Fault Frequency: 12
Reset counter: 40
Mileage: 164052 km
Time Indication: 0
Date: 2016.04.28
Time: 15:10:20
Freeze Frame:
RPM: 1184 /min
Temperature: 88.5°C
Overrun
Voltage: 13.26 V
Bin. Bits: 00000010
Readiness: 0000 0000
after running a 3 tests to see what comes up after clearing. i noticed the reset counter for a couple of the faults in during test 1 and 2 is different from test 3. for example for the first fault. po562 the reset counter on my first and second test log is 27 but for the third test it shows 26. this happens for a few of the 7 faults but not all. not really sure what this means if anything at all. i have read on them individually and will take steps to correct them but im trying to see if any of these could specifically be my problem so i could go at that first.
also the dates say 2006 but thats because of battery disconecting/reconecting itself overnight somehow(this was what made me finally switch it) and then me switching the battery with a brand new one. i know this makes it difficult to know exactly when faults came up but the mileage is correct so can make a rough estimate.
ill post up the full scan in another reply
also little update
since battery change the problem has been happening less and less :S i dont know if this is good or not. hasnt happend since my last post but i dont think its been solved just the new battery is not letting it happen as often (i think).
7 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 20
Reset counter: 27
Mileage: 161100 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Temperature: 33.0°C
Engine Off
Load: 0.0 %
Voltage: 0.61 V
Freeze Frame:
Fault Priority: 4
Fault Frequency: 8
Reset counter: 27
Mileage: 161100 km
Time Indication: 0
Date: 2006.03.15
Time: 12:01:27
Freeze Frame:
RPM: 0 /min
Temperature: 61.5°C
Engine Off
Load: 0.0 %
Voltage: 0.61 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 4
Mileage: 161100 km
Time Indication: 0
Date: 2006.03.15
Time: 12:03:41
Freeze Frame:
RPM: 832 /min
Temperature: 93.0°C
Idle
Load: 14.9 %
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 29
Reset counter: 40
Mileage: 161737 km
Time Indication: 0
Date: 2016.04.09
Time: 21:58:22
Freeze Frame:
RPM: 1344 /min
Temperature: 30.0°C
Idle
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 4
Mileage: 161999 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Temperature: 13.5°C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 12
Reset counter: 40
Mileage: 164052 km
Time Indication: 0
Date: 2016.04.28
Time: 15:10:20
Freeze Frame:
RPM: 1184 /min
Temperature: 88.5°C
Overrun
Voltage: 13.26 V
Speed: 48.0 km/h
Freeze Frame:
Fault Priority: 5
Fault Frequency: 12
Reset counter: 40
Mileage: 164052 km
Time Indication: 0
Date: 2016.04.28
Time: 15:10:20
Freeze Frame:
RPM: 1184 /min
Temperature: 88.5°C
Overrun
Voltage: 13.26 V
Bin. Bits: 00000010
also little update
#14
FIRST SCAN
Tuesday,03,May,2016,20:42:17:11863
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
Ross-Tech: Home
VIN: WAUKH74F67N044328 License Plate:
Mileage: 164570km-102259mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 36 37 42 46 47 4F 52 53
55 56 61 62 67 72 77
VIN: WAUKH74F67N044328 Mileage: 164570km-102259miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Cannot be reached 1100
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
7 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 20
Reset counter: 27
Mileage: 161100 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Temperature: 33.0°C
Engine Off
Load: 0.0 %
Voltage: 0.61 V
Freeze Frame:
Fault Priority: 4
Fault Frequency: 8
Reset counter: 27
Mileage: 161100 km
Time Indication: 0
Date: 2006.03.15
Time: 12:01:27
Freeze Frame:
RPM: 0 /min
Temperature: 61.5°C
Engine Off
Load: 0.0 %
Voltage: 0.61 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 4
Mileage: 161100 km
Time Indication: 0
Date: 2006.03.15
Time: 12:03:41
Freeze Frame:
RPM: 832 /min
Temperature: 93.0°C
Idle
Load: 14.9 %
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 29
Reset counter: 40
Mileage: 161737 km
Time Indication: 0
Date: 2016.04.09
Time: 21:58:22
Freeze Frame:
RPM: 1344 /min
Temperature: 30.0°C
Idle
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 4
Mileage: 161999 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Temperature: 13.5°C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 12
Reset counter: 40
Mileage: 164052 km
Time Indication: 0
Date: 2016.04.28
Time: 15:10:20
Freeze Frame:
RPM: 1184 /min
Temperature: 88.5°C
Overrun
Voltage: 13.26 V
Speed: 48.0 km/h
Freeze Frame:
Fault Priority: 5
Fault Frequency: 12
Reset counter: 40
Mileage: 164052 km
Time Indication: 0
Date: 2016.04.28
Time: 15:10:20
Freeze Frame:
RPM: 1184 /min
Temperature: 88.5°C
Overrun
Voltage: 13.26 V
Bin. Bits: 00000010
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F2 910 156 G HW: 09L 927 156 C
Component: AG6 09L 3.2 FSI USA 0010
Revision: --H01--- Serial number: 4218627
Coding: 0000002
Shop #: WSC 02325 785 00200
VCID: 2959896280D7757609-807C
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AD HW: 4F0 614 517 AA
Component: ESP8 quattro H01 0070
Revision: 00000000 Serial number: 00000000000000
Coding: 0020895
VCID: 66C3C25E51499A0EE4-8032
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 10
Reset counter: 229
Mileage: 161100 km
Time Indication: 0
Date: 2006.03.15
Time: 12:01:29
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x0282
Hex Value: 0x0024
Hex Value: 0x0183
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 E
Component: FBSAUDIC6 ELV H05 0100
Revision: 00H05000 Serial number: 10602501448705
Coding: 0000143
Shop #: WSC 49308 000 1048576
VCID: 25418552ECCF51162D-8070
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 731 T HW: 4E0 035 729
Component: Interfacebox H43 3360
Revision: 00000000 Serial number: 303HR067525574
Coding: 0001003
Shop #: WSC 93078 999 100678
VCID: 33656B0A521B3FA6B3-8066
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000002013846
Subsystem 3 - Serial number: 0129.05.120000000100010483ÿ
Subsystem 4 - Serial number: 010483ÿ
1 Fault Found:
02244 - Button in Control Head is Stuck
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 253
Mileage: 163993 km
Time Indication: 0
Date: 2016.04.27
Time: 13:08:09
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 0000000
Bin. Bits: 010
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000053 Serial number: 00000000544433
Coding: 0524326
Shop #: WSC 02145 785 00200
VCID: 1C37A0B6DF8590DE82-8048
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0113114
Shop #: WSC 02335 785 00200
VCID: 306F6406A30D04BECE-8064
Subsystem 1 - Part No: 4F1 910 113 B Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00146221
Shop #: WSC 02335
Address 0E: Media Player 1
Cannot be reached
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 F HW: 4F0 959 655 A
Component: 64 AIRBAG AUDI8RH29 0300
Revision: 14H29000 Serial number: 00359D0BBEN3
Coding: 0013876
VCID: 2A5B766E85D17E6E00-807E
Subsystem 1 - Serial number: 6332CSME12222727T
Subsystem 2 - Serial number: 6342CSME12091561U
Subsystem 3 - Serial number: 6352QSME136E1861H
Subsystem 4 - Serial number: 6362QSME13791851D
Subsystem 5 - Serial number: 63734SME124F342D2
Subsystem 6 - Serial number: 63834SME111B3D4F8
1 Fault Found:
01217 - Side Airbag Igniter; Driver Side (N199)
001 - Upper Limit Exceeded - MIL ON
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 C
Component: J0527 0410
Revision: 00H03000 Serial number: 90025061840086
Coding: 0012242
VCID: 275D8F5A96C343061F-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H07 0090
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 931 T
Component: KOMBIINSTR. M73 H18 0110
Revision: 00300000 Serial number: 5HN399K76
Coding: 2113363
Shop #: WSC 25566 001 1048576
VCID: 23459B4AE2FBAF2643-8076
Address 19: CAN Gateway Labels: 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 13008067268016
Coding: 6CFE73CC1B7104
Shop #: WSC 02334 785 00200
1 Fault Found:
02076 - Media Player Position 1 (R118)
004 - No Signal/Communication
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 172
Mileage: 161100 km
Time Indication: 0
Date: 2006.03.21
Time: 10:57:50
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
VCID: 61C9D142B867FD3611-8034
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 D
Component: MNS US H48 1100
Revision: 00000000 Serial number: 381GN067504307
Shop #: WSC 02323 785 00200
VCID: 387F5C264B7DDCFE86-806C
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0270
Revision: 00000000 Serial number: SY†
Coding: 0052971
Shop #: WSC 93078 999 85724
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01017603720000
Coding: 4618781
VCID: 2E537A7EB939124EDC-807A
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
1 Fault Found:
01503 - Bulb for 3rd Brake Light (M25)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 11
Reset counter: 5
Mileage: 161316 km
Time Indication: 0
Date: 2006.03.16
Time: 21:26:54
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H09 0240
Revision: PROD_01 Serial number: 00000000011122
Coding: 0000056
Shop #: WSC 45350 001 1048576
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000034445
Coding: 0002014
VCID: 5EB3EABE8919C2CE2C-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0270
Revision: 00000000 Serial number: 'qˆ
Coding: 0052971
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 B HW: 4F0 907 801 A
Component: EPB CB4C0060 H04 0060
Revision: --H04---
Coding: 0005022
Shop #: WSC 02324 785 00200
VCID: 1F4D97BACE938BC667-804A
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000016
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 H
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 394H0067673378
Coding: 0000002
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000090032
Shop #: WSC 94708 999 82916
Subsystem 1 - Part No: 4F0 915 105 E
Component: von VA0 1607260238
Coding: 344630393135313035452056413031363037323630323338
Shop #: WSC 00000 384 00290
5 Faults Found:
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 161100 km
Time Indication: 0
Date: 2006.03.21
Time: 10:57:05
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 161100 km
Time Indication: 0
Date: 2006.03.21
Time: 11:00:15
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 161100 km
Time Indication: 0
Date: 2006.03.21
Time: 11:00:25
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 161100 km
Time Indication: 0
Date: 2006.03.21
Time: 11:01:47
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 161100 km
Time Indication: 0
Date: 2006.03.21
Time: 11:08:43
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0052778
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000606010564
Shop #: WSC 12336 024 394758
VCID: 346768165715389EAA-8060
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0052778
1 Fault Found:
02111 - Motor for Window Regulator
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 223
Mileage: 164483 km
Time Indication: 0
Date: 2016.05.02
Time: 22:04:30
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H20 1130
Revision: 00000000 Serial number: 00000005069345
Coding: 0010900
VCID: 285F8C669BDD4C7E16-807C
End-------------------------(Elapsed Time: 02:37)--------------------------
Ross-Tech: Home
7 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 20
Reset counter: 27
Mileage: 161100 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Temperature: 33.0°C
Engine Off
Load: 0.0 %
Voltage: 0.61 V
Freeze Frame:
Fault Priority: 4
Fault Frequency: 8
Reset counter: 27
Mileage: 161100 km
Time Indication: 0
Date: 2006.03.15
Time: 12:01:27
Freeze Frame:
RPM: 0 /min
Temperature: 61.5°C
Engine Off
Load: 0.0 %
Voltage: 0.61 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 4
Mileage: 161100 km
Time Indication: 0
Date: 2006.03.15
Time: 12:03:41
Freeze Frame:
RPM: 832 /min
Temperature: 93.0°C
Idle
Load: 14.9 %
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 29
Reset counter: 40
Mileage: 161737 km
Time Indication: 0
Date: 2016.04.09
Time: 21:58:22
Freeze Frame:
RPM: 1344 /min
Temperature: 30.0°C
Idle
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 4
Mileage: 161999 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Temperature: 13.5°C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 12
Reset counter: 40
Mileage: 164052 km
Time Indication: 0
Date: 2016.04.28
Time: 15:10:20
Freeze Frame:
RPM: 1184 /min
Temperature: 88.5°C
Overrun
Voltage: 13.26 V
Speed: 48.0 km/h
Freeze Frame:
Fault Priority: 5
Fault Frequency: 12
Reset counter: 40
Mileage: 164052 km
Time Indication: 0
Date: 2016.04.28
Time: 15:10:20
Freeze Frame:
RPM: 1184 /min
Temperature: 88.5°C
Overrun
Voltage: 13.26 V
Bin. Bits: 00000010
Coding: 0000002
Coding: 0020895
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 10
Reset counter: 229
Mileage: 161100 km
Time Indication: 0
Date: 2006.03.15
Time: 12:01:29
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x0282
Hex Value: 0x0024
Hex Value: 0x0183
Hex Value: 0x00FF
Coding: 0000143
Coding: 0001003
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 253
Mileage: 163993 km
Time Indication: 0
Date: 2016.04.27
Time: 13:08:09
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 0000000
Bin. Bits: 010
Coding: 0524326
Coding: 0113114
Coding: 00064784
Shop #: WSC 02335
Coding: 00146221
Shop #: WSC 02335
Cannot be reached
Coding: 0013876
1 Fault Found:
Coding: 0012242
Coding: 2113363
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 172
Mileage: 161100 km
Time Indication: 0
Date: 2006.03.21
Time: 10:57:50
Coding: 0082954
Coding: 0052971
Coding: 4618781
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 11
Reset counter: 5
Mileage: 161316 km
Time Indication: 0
Date: 2006.03.16
Time: 21:26:54
Coding: 0000056
Coding: 0002014
Coding: 0052971
Revision: --H04---
Coding: 0005022
Coding: 0000016
Coding: 0000002
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 161100 km
Time Indication: 0
Date: 2006.03.21
Time: 10:57:05
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 161100 km
Time Indication: 0
Date: 2006.03.21
Time: 11:00:15
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 161100 km
Time Indication: 0
Date: 2006.03.21
Time: 11:00:25
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 161100 km
Time Indication: 0
Date: 2006.03.21
Time: 11:01:47
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 161100 km
Time Indication: 0
Date: 2006.03.21
Time: 11:08:43
Coding: 0052778
Coding: 0052778
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 223
Mileage: 164483 km
Time Indication: 0
Date: 2016.05.02
Time: 22:04:30
Coding: 0010900
#15
second scan
Tuesday,03,May,2016,22:27:36:11863
Ross-Tech: Home
Mileage: 164580km-102265mi Repair Order:
VIN: WAUKH74F67N044328 Mileage: 164580km-102265miles
03-ABS Brakes -- Status: OK 0000
07-Control Head -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
7 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 20
Reset counter: 26
Mileage: 161100 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Temperature: 33.0°C
Engine Off
Load: 0.0 %
Voltage: 0.61 V
Freeze Frame:
Fault Priority: 4
Fault Frequency: 8
Reset counter: 26
Mileage: 161100 km
Time Indication: 0
Date: 2006.03.15
Time: 12:01:27
Freeze Frame:
RPM: 0 /min
Temperature: 61.5°C
Engine Off
Load: 0.0 %
Voltage: 0.61 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 3
Mileage: 161100 km
Time Indication: 0
Date: 2006.03.15
Time: 12:03:41
Freeze Frame:
RPM: 832 /min
Temperature: 93.0°C
Idle
Load: 14.9 %
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 30
Reset counter: 40
Mileage: 161737 km
Time Indication: 0
Date: 2016.04.09
Time: 21:58:22
Freeze Frame:
RPM: 672 /min
Mass Air / Rev.: 114.5 mg/str
Temperature: 90.0°C
Idle
Absolute Pres.: 351.1 mbar
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 3
Mileage: 161999 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Temperature: 13.5°C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 12
Reset counter: 40
Mileage: 164052 km
Time Indication: 0
Date: 2016.04.28
Time: 15:10:20
Freeze Frame:
RPM: 1184 /min
Temperature: 88.5°C
Overrun
Voltage: 13.26 V
Speed: 48.0 km/h
Freeze Frame:
Fault Status: 10100010
Fault Priority: 5
Fault Frequency: 12
Reset counter: 40
Mileage: 164052 km
Time Indication: 0
Date: 2016.04.28
Time: 15:10:20
Freeze Frame:
RPM: 1184 /min
Temperature: 88.5°C
Overrun
Voltage: 13.26 V
Bin. Bits: 00000010
Coding: 0000002
Coding: 0020895
Coding: 0000143
Coding: 0001003
Coding: 0524326
Coding: 0113114
Coding: 00064784
Shop #: WSC 02335
Coding: 00146221
Shop #: WSC 02335
Cannot be reached
Coding: 0013876
1 Fault Found:
Coding: 0012242
Coding: 2113363
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 226
Mileage: 164584 km
Time Indication: 0
Date: 2016.05.03
Time: 22:19:56
Coding: 0082954
Coding: 0052971
Coding: 4618781
Coding: 0000056
Coding: 0002014
Coding: 0052971
Revision: --H04---
Coding: 0005022
Coding: 0000016
Coding: 0000002
Coding: 0052778
Component: SDS 3
Coding: 0052778
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 226
Mileage: 164584 km
Time Indication: 0
Date: 2016.05.03
Time: 22:18:56
Coding: 0010900
End-------------------------(Elapsed Time: 02:32)--------------------------
Ross-Tech: Home
7 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 20
Reset counter: 26
Mileage: 161100 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Temperature: 33.0°C
Engine Off
Load: 0.0 %
Voltage: 0.61 V
Freeze Frame:
Fault Priority: 4
Fault Frequency: 8
Reset counter: 26
Mileage: 161100 km
Time Indication: 0
Date: 2006.03.15
Time: 12:01:27
Freeze Frame:
RPM: 0 /min
Temperature: 61.5°C
Engine Off
Load: 0.0 %
Voltage: 0.61 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 3
Mileage: 161100 km
Time Indication: 0
Date: 2006.03.15
Time: 12:03:41
Freeze Frame:
RPM: 832 /min
Temperature: 93.0°C
Idle
Load: 14.9 %
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 30
Reset counter: 40
Mileage: 161737 km
Time Indication: 0
Date: 2016.04.09
Time: 21:58:22
Freeze Frame:
RPM: 672 /min
Temperature: 90.0°C
Idle
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 3
Mileage: 161999 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Temperature: 13.5°C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 12
Reset counter: 40
Mileage: 164052 km
Time Indication: 0
Date: 2016.04.28
Time: 15:10:20
Freeze Frame:
RPM: 1184 /min
Temperature: 88.5°C
Overrun
Voltage: 13.26 V
Speed: 48.0 km/h
Freeze Frame:
Fault Priority: 5
Fault Frequency: 12
Reset counter: 40
Mileage: 164052 km
Time Indication: 0
Date: 2016.04.28
Time: 15:10:20
Freeze Frame:
RPM: 1184 /min
Temperature: 88.5°C
Overrun
Voltage: 13.26 V
Bin. Bits: 00000010
Coding: 0000002
Coding: 0020895
Coding: 0000143
Coding: 0001003
Coding: 0524326
Coding: 0113114
Coding: 00064784
Shop #: WSC 02335
Coding: 00146221
Shop #: WSC 02335
Cannot be reached
Coding: 0013876
1 Fault Found:
Coding: 0012242
Coding: 2113363
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 226
Mileage: 164584 km
Time Indication: 0
Date: 2016.05.03
Time: 22:19:56
Coding: 0082954
Coding: 0052971
Coding: 4618781
Coding: 0000056
Coding: 0002014
Coding: 0052971
Revision: --H04---
Coding: 0005022
Coding: 0000016
Coding: 0000002
Coding: 0052778
Component: SDS 3
Coding: 0052778
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 226
Mileage: 164584 km
Time Indication: 0
Date: 2016.05.03
Time: 22:18:56
Coding: 0010900
#18
Thanks shamoye. I read that inside the relay can get stuck, and if no start happens i should pull it out tap it and try again. Ialso just looked up how to test the relay with multimeter, but since no start hasnt happend for a while and theres no specific way to set it off. Im wondering if the test will just tell me its good only for it to happen again tomorow or next week. Do you think it would be wise to just replace it regardless since it has thrown code ?
#19
Little update.
After almost a month of luck it finally had the no start again. I scanned to see if anything pops up and i got new codes for authentication. I assume these solve themself and when car is starting they dont show. Car didnt start on sunday and hasnt started since but im not worried because it has taken a few days before.
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb Part No SW: 4F0 910 852 B HW: 4F0 905 852 E Component: FBSAUDIC6 ELV H05 0100 Revision: 00H05000 Serial number: 10602501448705 Coding: 0000143 Shop #: WSC 49308 000 1048576 VCID: 25418552ECCF51162D-8070 Subsystem 1 - Part No: 4F0 910 131 L Component: FBSAUDIC6 EZS H45 0080 Subsystem 2 - Part No: 4F0 910 335 Component: FBSAUDIC6 KSG H27 0080
1 Fault Found: 00526 - Brake Light Switch (F) 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00111001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 21 Mileage: 165211 km Time Indication: 0 Date: 2016.05.08 Time: 15:51:48
Address 46: Central Conv. Labels: 4F0-910-289.lbl Part No SW: 4F0 910 289 G HW: 4F0 907 289 G Component: Komfortgeraet H22 0170 Revision: 01700022 Serial number: 01017603720000 Coding: 4618781 Shop #: WSC 02335 785 00200 VCID: 2E537A7EB939124EDC-807A Subsystem 1 - Part No: 1K0 951 605 C Component: LIN BACKUP HORN H03 1301 2 Faults Found: 01503 - Bulb for 3rd Brake Light (M25) 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 3 Fault Frequency: 41 Reset counter: 21 Mileage: 164638 km Time Indication: 0 Date: 2016.05.04 Time: 18:58:38 00526 - Brake Light Switch (F) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 3 Reset counter: 21 Mileage: 165211 km Time Indication: 0 Date: 2016.05.08 Time: 15:51:16
The centar breaklight has been giving me a warning on dash and its on and off. Sometimes the middle break light works sometimes it doesnt and this is relativly new where as the no start is not. But because the breaklight is triggering fault in authentication module it would make sense thats causing the no start but just never showed me on the dash until recently. I dont know if that makes sense or not. Im going to open the hatch and check out the wiring and conection for the break light.
I think this is my best bet because when car is starting i never have authentication codes. Now that i can scan while its not starting it has authentication codes about break light. I didnt have vcds befor so dont know what usually showed up during no start.
thanks to anyone who actually reads all of this. I know its alot but i try to give as much detail as i can.
