A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
200,000 mile club
Old 04-08-2015, 10:03 PM
  #41
FormulaElement's Avatar
Originally Posted by mike101
Total redo exept chains. For some reason they mad expensive. I know some ppl might say "ooo chain strech ect ect". How many ppl actually seen the chain vs reading about possible scenario? Chain is a chain as long I don't see sign of abuse (read marks from hitting and wobbling) I'm fine with it. The guide you referring to was there intact. It just felt off. It supposed to be supported by 2 screws but like I said I just got the car never had to deal with 4.2 chain driven one so I'm waiting for parts to see if previous owner put wrong ones or it is the way that supposed to be. Beside that its all timing parts adjusters, rails, tencioners, water pump, intake gaskets, valve cover gaskets thermostat water pump Crankshaft seals. Also B1S1 oxy since that was what I read with VAG at the time of purchase.
Ah ok that sounds better. The timing guides don't actually get screwed on there and are designed to move around on those pins and can fall off when the back cover isn't on.
Old 09-22-2015, 06:41 AM
  #42
HK-Steve's Avatar
Just clicked over the 210k Km's today. Still going strong..
Old 09-28-2015, 11:35 PM
  #43
tsbruford's Avatar
I'm at 182K miles which is 292K km. Just replaced Plugs, coils, had trans fluid checked and topped. Looks like it will go strong for a while. 2006 A6 3.2 Quattro. Pleasure to drive.
Old 09-29-2015, 09:30 AM
  #44
HK-Steve's Avatar
Nice tsbruford..
Old 10-08-2015, 05:36 PM
  #45
cmarcks's Avatar
I've got a 2005 3.2 with 202k and a 2006 3.2 s-line with 215k. Also a 2002 c5 4.2 with 224k and the old man has a d2 a8l with 210k and a d3 a8 short with 160k. Bought them all roughly around the 150k area and did purely p.m. stuff like timing belts and Trans fluid changes. Never a major issue, except a blown air strut recently on the d3.
Old 10-09-2015, 02:43 AM
  #46
KevinGary's Avatar
How did you do timing belts on the 05 and 06 3.2s?
Old 10-09-2015, 07:24 PM
  #47
cmarcks's Avatar
The point was to add a bit more 200k plus history to the otherwise perfectly relevant 3.2 models and it's quite easy for most to infer that applies to the 4.2s. I'll try and be a nice guy for once and assume you're just trying to be funny rather than a *****!
Old 10-10-2015, 04:29 AM
  #48
KevinGary's Avatar
Since the 3.2 does not have a timing belt I was wondering how you replaced it in two different cars.
Old 10-18-2015, 10:11 AM
  #49
beep-beep's Avatar
he mean " routine maintanance items. He probably changed belts on A8 and infer similar maintenance items on A6
Old 10-20-2015, 05:29 PM
  #50
cmarcks's Avatar
Yes sir. Unfortunately I may need to retract that mostly trouble-free past as I've got a likely injector issue on one of those 3.2 cars. I trust It'll be back on the path to 300k shortly.
Quick Reply: 200,000 mile club
