2005 A6 3.2 FSI Quattro Issues
Hi All.
New poster so please be gentle with me.
I bought my car last Jan and fell in love straight away was a dream to drive either sat back relaxing or on occasion like i had just stole it.
The car came with 2 issues,
1 Parking Brake Malfunction,
2 Adaptive Headlight Malfunction.
Neither of theses was a major problem.
after 6 months the car has developed some strange behaviour.
Starts lovely on first turn of the key and when cold drives lovely.
as soon as the car has reached operating temp if i accelerate mildly i get a judder between 1500 and 2000 rpm. above 2000 and she is sweet as a nut or if i change down a gear using the flappy paddles.
So far the car has been in and out of my local garage so much its crazy.
The car was scanned with VCDS by an owner in swansea for the price of a curry.
only code that came up was camshaft position sensor implausible signal, so i replaced that with fingers crossed.
Nope didnt make any difference
So bit the bullet and went and bought VCDS myself in the hope of monitoring the car while i was on a long drive.
Below is the most recent scan taken this morning.
Saturday,07,February,2015,09:56:58:03255
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.1.1 (x64)
Data version: 20150130
Mileage: 244170km-151720mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 55 56
61 62 72 76 77
VIN: Mileage: 244170km-151720miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
Part No SW: 4F0 910 115 HW: 4F0 907 115
Component: 3.2l V6 FSI G 0040
Revision: --H14--- Serial number:
Coding: 01050003190F0120
Shop #: WSC 00533 210 08330
VCID: 5BB5A2529A2937F95B2-800E
3 Faults Found:
18010 - Power Supply Terminal 30
P1602 - 000 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00011000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Mass Air / Rev.: 0.0 mg/str
Temperature: -48.0*C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
18018 - Internal Control Module
P1610 - 000 - Memory Check Sum Error - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 24
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Temperature: 36.0*C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
18061 - Please check DTC Memory of ABS Controller
P1653 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 24
Mileage: 243678 km
Time Indication: 0
Date: 2015.02.04
Time: 13:08:22
Freeze Frame:
RPM: 1344 /min
Mass Air / Rev.: 125.4 mg/str
Temperature: 36.0*C
Idle
Load: 11.8 %
Speed: 0.0 km/h
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F0 910 157 E HW: 09L 927 156
Component: AG6 09L 3.2 FSI RdW 0060
Revision: 00000001 Serial number: 0019978
Coding: 0000001
VCID: 2643C3A691EBBA1134C-8073
1 Fault Found:
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 33
Mileage: 243678 km
Time Indication: 0
Date: 2015.02.04
Time: 13:08:21
Freeze Frame:
RPM: 192 /min
RPM: 192 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 48.0*C
T.B. Angle: 0.0*
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 A HW: 4F0 614 517 A
Component: ESP8 quattro H03 0330
Revision: 00000000 Serial number: 00000000000000
Coding: 0004511
Shop #: WSC 02335 785 00200
VCID: 224BDFB6FDC34631584-8077
2 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 65
Mileage: 243678 km
Time Indication: 0
Date: 2015.02.04
Time: 13:08:23
Freeze Frame:
Hex Value: 0x0280
Hex Value: 0x6082
Hex Value: 0x0000
Hex Value: 0x0091
Hex Value: 0x00FF
18265 - Load Signal
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 65
Mileage: 243678 km
Time Indication: 0
Date: 2015.02.04
Time: 13:08:23
Freeze Frame:
Hex Value: 0x0280
Hex Value: 0x6082
Hex Value: 0x0000
Hex Value: 0x0090
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0220
Revision: 31050601 Serial number: 10600200020863
Coding: 0000019
Shop #: WSC 00533 210 80580
VCID: 63C59AB2A2590F39132-8036
Subsystem 1 - Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H43 0060
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H39 0040
No fault code found.
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 729 Q HW: 4E0 035 729
Component: Interfacebox H43 0500
Revision: 00000000 Serial number: 350DG047511716
Coding: 0000002
VCID: 377D1EE2464133999FA-8062
Subsystem 1 - Part No: 4F0 910 609
Component: Bedienteil MMIC6H03 0870
Subsystem 2 - Serial number: 00000000008530
Subsystem 3 - Serial number: 0121.04.040000000100010015ÿ
Subsystem 4 - Serial number: 010015ÿ
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 2
Reset counter: 72
Mileage: 243705 km
Time Indication: 0
Date: 2015.02.04
Time: 16:27:57
Freeze Frame:
Bin. Bits: 10
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F2 820 043 C
Component: KLIMABETAETIGUNGH11 0060
Revision: 00000021 Serial number: 00000000018129
Coding: 0525318
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H14 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0003121
VCID: 66C383A6516B7A11F4C-8033
Subsystem 1 - Part No: 4F2 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H04 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0040
Coding: 00141886
Shop #: WSC 02335
3 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 64
Mileage: 243676 km
Time Indication: 0
Date: 2015.02.04
Time: 13:07:00
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 64
Mileage: 243676 km
Time Indication: 0
Date: 2015.02.04
Time: 13:07:00
00924 - Relay for Headlamp Cleaning System (J39)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 21
Reset counter: 32
Mileage: 243676 km
Time Indication: 0
Date: 2015.02.04
Time: 13:08:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 C HW: 4E0 035 111
Component: CD-Changer H43 0340
Revision: 00000000 Serial number: AUZ5ZBD3000829
Shop #: WSC 00000 000 00000
VCID: 1939F85AD09505E989E-804C
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 G HW: 4F0 959 655
Component: 20 AIRBAG AUDI8RH24 0110
Revision: 07H24000 Serial number: 00358D05AYD5
Coding: 0012848
VCID: 2B5532928A098779EB2-807E
Subsystem 1 - Serial number: 6332CSME0278646D7
Subsystem 2 - Serial number: 6342CSME02774E545
Subsystem 3 - Serial number: 6351HSME023A0926%
Subsystem 4 - Serial number: 6361HSME022F053FA
Subsystem 5 - Serial number: 6371VSME022B5979S
Subsystem 6 - Serial number: 6381VSME022B4B3EV
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H06 0130
Revision: 00H06000 Serial number: 90025041200139
Coding: 0102141
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H04 0080
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 950 G
Component: KOMBIINSTR. M73 H07 0630
Revision: 00600000 Serial number: 49E33RG44
Coding: 0065443
Shop #: WSC 00011 067 57207
VCID: 1E33EB46C9BB62D17CC-804B
1 Fault Found:
01298 - Instrument Cluster Lamp Test
000 - - - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 65
Mileage: 243705 km
Time Indication: 0
Date: 2015.02.04
Time: 14:00:10
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
Component: Gateway H09 0030
Revision: 09 Serial number: 08008043230071
Coding: ECFE73C41B1104
VCID: 275DCEA296E1A3190FA-8072
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H10 0020
Revision: 00000000 Serial number: g2
Coding: 0000538
VCID: 2959C89A80F5956919E-807C
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
Component: Komfortgeraet H14 0090
Revision: 00900014 Serial number: 01000133450000
Coding: 0131571
VCID: 2C57318E8F078041E28-8079
Subsystem 1 - Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0010
Address 47: Sound System Labels: 4F0-910-223-AS.lbl
Part No SW: 4F0 910 223 B HW: 4F0 035 223
Component: Amp.-ASK H09 0270
Revision: 00000001 Serial number: 01604040010861
Coding: 0000005
VCID: 1D31EC4AC4BD79C9656-8048
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H07 0040
Revision: Serial number: 00000000007815
Coding: 0001104
VCID: 5EB3AB46893B22D13CC-800B
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H10 0020
Revision: 00000000 Serial number: Wd
Coding: 0000538
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C43HC002 H03 0020
Revision: C43HC002
Coding: 0005021
VCID: 5DB1AC4A843D39C9256-8008
2 Faults Found:
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 65
Mileage: 243672 km
Time Indication: 0
Date: 2015.02.04
Time: 13:30:46
Freeze Frame:
Voltage: 12.73 V
Count: 236
16347 - Control Module - EEPROM Error
014 - Defective - MIL ON
Freeze Frame:
Fault Status: 11101110
Fault Priority: 4
Fault Frequency: 231
Reset counter: 255
Mileage: 152712 km
Time Indication: 0
Date: 2010.12.20
Time: 17:10:32
Freeze Frame:
Voltage: 12.53 V
Count: 187
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 A HW: 4F0 907 357 A
Component: AFS 1 H03 0010
Coding: 0000016
Shop #: WSC 02331 785 00200
VCID: 2447D9AEE7D748012A8-8071
Subsystem 1 - Part No: 4F0 941 329
Component: AFS-Modul links H05 0010
Subsystem 2 - Part No: 4F0 941 329
Component: AFS-Modul rechtsH05 0010
1 Fault Found:
02626 - Dynamic Cornering Light Motor; Right (V319)
010 - Open or Short to Plus - MIL ON
Freeze Frame:
Fault Status: 11101010
Fault Priority: 2
Fault Frequency: 22
Reset counter: 40
Mileage: 243672 km
Time Indication: 0
Date: 2015.02.04
Time: 13:06:09
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 C HW: 4F0 035 541
Component: TUNER EU/US/RDW H41 0290
Revision: 00000000 Serial number: 352EJ047521418
Coding: 0000001
VCID: 204FD5BEF3CF54214E0-8075
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 64
Mileage: 243678 km
Time Indication: 0
Date: 2015.02.04
Time: 12:48:54
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0470
Revision: 00000000 Serial number: 00000000013464
VCID: 2345DAB2E2D94F39532-8076
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 1411030952
Coding: 344630393135313035442056413031343131303330393532
4 Faults Found:
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 243678 km
Time Indication: 0
Date: 2015.02.04
Time: 13:06:09
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 243678 km
Time Indication: 0
Date: 2015.02.04
Time: 13:06:16
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 244170 km
Time Indication: 0
Date: 2015.02.06
Time: 22:14:03
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 244170 km
Time Indication: 0
Date: 2015.02.06
Time: 22:10:11
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 795 A
Component: TSG HL H09 0010
Coding: 0000002
VCID: 2A5B379685F39E71104-807F
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 794 A
Component: TSG HR H09 0010
Coding: 0000002
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 HW: 4F0 919 283
Component: Parkhilfe 4-Kan H09 0020
Revision: --.--.-- Serial number: 11730412404887
Coding: 0001006
VCID: 61C990BAB8451D2901E-8034
1 Fault Found:
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 25
Mileage: 243678 km
Time Indication: 0
Date: 2015.02.04
Time: 13:30:08
Address 77: Telephone Labels: 4E0-910-333.lbl
Part No SW: 4E0 910 333 D HW: 4E0 862 333 C
Component: TELEFONMODUL EU 0650
Revision: 00000003 Serial number: T2AUDX0307H235
Coding: 0000006
End-------------------------(Elapsed Time: 02:32)--------------------------
Any help or pointers as to the issue would be greatly appreciated.
FYI: this is the first time that the Transmission and ABS have kicked up a fault code.
Regards
J
61 62 72 76 77
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 24
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Temperature: 36.0*C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 24
Mileage: 243678 km
Time Indication: 0
Date: 2015.02.04
Time: 13:08:22
Freeze Frame:
RPM: 1344 /min
Temperature: 36.0*C
Idle
Load: 11.8 %
Speed: 0.0 km/h
Coding: 0000001
1 Fault Found:
18265 - Load Signal
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 33
Mileage: 243678 km
Time Indication: 0
Date: 2015.02.04
Time: 13:08:21
Freeze Frame:
RPM: 192 /min
RPM: 192 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 48.0*C
T.B. Angle: 0.0*
Coding: 0004511
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 65
Mileage: 243678 km
Time Indication: 0
Date: 2015.02.04
Time: 13:08:23
Freeze Frame:
Hex Value: 0x0280
Hex Value: 0x6082
Hex Value: 0x0000
Hex Value: 0x0091
Hex Value: 0x00FF
18265 - Load Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 65
Mileage: 243678 km
Time Indication: 0
Date: 2015.02.04
Time: 13:08:23
Freeze Frame:
Hex Value: 0x0280
Hex Value: 0x6082
Hex Value: 0x0000
Hex Value: 0x0090
Hex Value: 0x00FF
Coding: 0000019
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 72
Mileage: 243705 km
Time Indication: 0
Date: 2015.02.04
Time: 16:27:57
Freeze Frame:
Bin. Bits: 10
Coding: 0525318
Coding: 0003121
Coding: 00062736
Shop #: WSC 02335
Coding: 00141886
Shop #: WSC 02335
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 64
Mileage: 243676 km
Time Indication: 0
Date: 2015.02.04
Time: 13:07:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 64
Mileage: 243676 km
Time Indication: 0
Date: 2015.02.04
Time: 13:07:00
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 21
Reset counter: 32
Mileage: 243676 km
Time Indication: 0
Date: 2015.02.04
Time: 13:08:00
Coding: 0012848
Coding: 0102141
Coding: 0065443
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 65
Mileage: 243705 km
Time Indication: 0
Date: 2015.02.04
Time: 14:00:10
Coding: 0000538
Coding: 0131571
Coding: 0000005
Coding: 0001104
Coding: 0000538
Revision: C43HC002
Coding: 0005021
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 65
Mileage: 243672 km
Time Indication: 0
Date: 2015.02.04
Time: 13:30:46
Freeze Frame:
Voltage: 12.73 V
Count: 236
Freeze Frame:
Fault Priority: 4
Reset counter: 255
Mileage: 152712 km
Time Indication: 0
Date: 2010.12.20
Time: 17:10:32
Freeze Frame:
Voltage: 12.53 V
Count: 187
Coding: 0000016
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 22
Reset counter: 40
Mileage: 243672 km
Time Indication: 0
Date: 2015.02.04
Time: 13:06:09
Coding: 0000001
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 64
Mileage: 243678 km
Time Indication: 0
Date: 2015.02.04
Time: 12:48:54
4 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 243678 km
Time Indication: 0
Date: 2015.02.04
Time: 13:06:09
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 243678 km
Time Indication: 0
Date: 2015.02.04
Time: 13:06:16
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 244170 km
Time Indication: 0
Date: 2015.02.06
Time: 22:14:03
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 244170 km
Time Indication: 0
Date: 2015.02.06
Time: 22:10:11
Coding: 0000002
Coding: 0000002
Coding: 0001006
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 25
Mileage: 243678 km
Time Indication: 0
Date: 2015.02.04
Time: 13:30:08
Coding: 0000006
Regards
J
<hr size="1" style="color: rgb(221, 221, 221); background-color: rgb(221, 221, 221);"><!-- / icon and title --> Jon, welcome aboard!
The parking brake fault is typically caused by one of three issues: bad switch on the console, damaged wiring to the electronic mechanism or a bad parking brake mechanism.
The adaptive headlight error can be caused by different things. Most are going to be £££ !
even tho a battery check shows it as healthy.
I think it might be the mmi software.
just more concerned with the judder/stutter worried im damaging the engine.
However i dont use it in case it stays locked on.
cheers
+2 on battery.
That may not however solve the 'judder'.
my guess is torque converter on that bit.
VCDS also unlikely to detect issue if it is the torque converter.
Since others have suggested the battery, I will suggest a plan based on hrc4u's suggestion and not assuming the battery is good or bad.
I would start by trying to eliminate anything that looks like a intermittent error. In my experience many low battery or voltage errors are 1 time and go away with a battery that stays fully charged.
If you sort the VCDS errors by date/time there are a couple of interesting times:
Date: 2010.12.20
.Time: 17:10:32
Date: 2015.02.04
.Time: 12:48:54
.Time: 13:06:09-13:08:23
.Time: 13:30:08
.Time: 13:30:46
.Time: 14:00:10
.Time: 16:27:57
Date: 2015.02.06
.Time: 22:10:11
.Time: 22:14:03
Date: 2015.02.04, Time: 12:48:54 - is a low voltage error
A bunch of errors between 13:06-13:09 - looks like you were not driving at this time
I am going to ignore the first error (2010) and the later errors for now, and the headlight motor error at 13:06
Here is what I would do:
Make sure the battery is fully charged using a trickle charger to make sure that before the is started there is a full charge even if there is a short somewhere that may be draining battery or the alternator isn't working properly.
Clear the errors on Address 02,03,09,56,61,76 to get rid of prior errors so only current issues are in the log.
Clear Address 01.
There are 2 errors that don't have timestamps, so need to find out when these get recorded as they are only 1 time errors.
Fault Frequency: 1
Fault Frequency: 1
When the battery is fully charged, start the car, run another scan, and post the new log.
Date: 2010.12.20
.Time: 17:10:32
Date: 2015.02.04
.Time: 12:48:54
.Time: 13:30:08
.Time: 13:30:46
.Time: 14:00:10
.Time: 16:27:57
Date: 2015.02.06
.Time: 22:10:11
.Time: 22:14:03
Clear Address 01.
Fault Frequency: 1
Fault Frequency: 1
check health of battery with a refractometer! i have no errors but i have a bad battery though...my acid level is around 1.21 when checking with refractometer...and doesn't climb even if i charged it 2 days with a ctek xs25 charger....
lots of modules will not perform good if you have a bad battery... =)
cheers/H
cheers/H
