2005 A6 3.2 FSI Quattro Issues
#21
Hi All,
Well today I decided to look at the transmission.
So took it to the garage and had filter gasket and oil change done.
What a difference!!!!!! the judder has now disappeared and the gear changes are as smooth as silk. so I am one happy Audi owner again instead of cursing repeatedly.
Still have the parking brake and adaptive headlight to sort but one thing at a time.
Thank you to all those who posted advice and ideas.
I have exactly the same electrical issues with the parking brake and adaptive headlight minus the engine judder as I did replace my tranny fluids around 75K.
on the adaptive headlight front I replaced the module with a newer one but that did not help, I checked the wiring to the sensors that are attached to the suspension front and rear on Drivers side and they looked ok, so everything is pointing to the ligh cluster itself, which I'm not willing to replace when the lights work fine, they just don't move.
The EPB issue is the most annoying and have not been able to locate any other available fix than the one found on this TSB. <http://uberlame.com/a6_tsb/Brakes/Electronic parking brake warning light on; parking brake doesn%27t always release.pdf>
which the dealer won't do for me unless I replace the module for a new one.
have you had any progress on this issue?
#22
Hello Jon6373
