2005 A6 3.2L Jerks when it shifts sometimes
#11
The tranny holds 9qts of fluid, however changing the fluid means you drop the pan and remove the 5 quarts of fluid that come out and replace that 5 quarts. Since the remaining 4 qts will be in various parts of the tranny that simply wont' come out when the pan is dropped.
If you do a flush, it will be more expensive, since you will actually be using more tranny fluid than the 9qts.
#12
The dealer gets a little more than $1k for a flush. You won't regret it.
#14
That's what I used in my2006 3.2. The shifting was noticeably smoother after the change. I just drained and refilled(no filter change or pan drop) at about 80K
