A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
2005 A6 3.2L Jerks when it shifts sometimes
Old 05-26-2015, 03:41 PM
  #11
raj99's Avatar
Originally Posted by Atkmmercado
I appreciate everyones input. Does anyone know how much audi charges for a transmission fluid change? and what is the best ATF? I would only get it done at audi im not risking some idiot mechanic not knowing what he is doing messing up my car.
read the link I sent you and also try using the search. The 'best' is what came in the vehicle (ZF Lifeguard). Therefore, my advice would be swap it out with what the original manufacturer (ZF) uses.
The tranny holds 9qts of fluid, however changing the fluid means you drop the pan and remove the 5 quarts of fluid that come out and replace that 5 quarts. Since the remaining 4 qts will be in various parts of the tranny that simply wont' come out when the pan is dropped.
If you do a flush, it will be more expensive, since you will actually be using more tranny fluid than the 9qts.
Old 05-27-2015, 04:25 PM
  #12
KevinGary's Avatar
The dealer gets a little more than $1k for a flush. You won't regret it.
Old 06-15-2015, 02:34 PM
  #13
Atkmmercado's Avatar
I have looked everywhere and i can not seem to find an answer. Is LG6 the same as G055005A2? And is ZF LG6 the fluid that came stock in my A6?
Old 06-18-2015, 04:56 PM
  #14
occhis's Avatar
That's what I used in my2006 3.2. The shifting was noticeably smoother after the change. I just drained and refilled(no filter change or pan drop) at about 80K
audisport12
09-07-2008 06:31 AM
asiu28
02-03-2003 02:55 PM
peadrob
11-18-2002 08:22 PM
TTowsonTT
10-24-2002 03:25 PM
Johnny-cat
Audi 100 / A6 (C4 Platform)
9
09-20-2001 11:27 AM
Quick Reply: 2005 A6 3.2L Jerks when it shifts sometimes
