A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
2005 A6 4.2 Bluetooth Module location?
Old 05-19-2013, 06:52 AM
PJSalerno2's Avatar
Default 2005 A6 4.2 Bluetooth Module location?
I installed a Dension Gateway 500 MOST & BTA1500 bluetooth and want to bypass the OEM Bluetooth module. Dension supplied the bypass parts but need to locate the OEM module. I've read it is under the drivers seat, but cant access or figure out how to remove the seat. Anyone have instructions with pics? Thanks!
Old 05-19-2013, 05:57 PM
MainlandMig's Avatar
cant confirm if its located under the seats but getting under there is very easy
there are four torx screws at each corner holding the tracks to the floor
the torx screws should have some plastic cosmetic covers that are easily broken and the rear track ends can break also
unscrew and lift up the seat at the front
there will be a wiring harness attached to the floor so dont yank the seat all the way back but the harness has enough slack so u can do what u need to do without disconnecting the harness
maybe this is the unit peaking through just to the right of the stroage drawer...may be attached to a protective plate
junior7577
10
07-16-2017 06:32 AM
hamilton
A6 (C7 Platform) Discussion
03-13-2015 11:27 AM
Roby466
Want To Buy - Archive (NO NEW POSTS HERE)
10-24-2014 10:55 PM
d6lc
03-09-2013 09:52 PM
BVegas
04-25-2010 06:35 PM
Quick Reply: 2005 A6 4.2 Bluetooth Module location?
