2005 Audi A6 3.2 Quattro.. Can someone tell me the name or part# of this part
Hope everyone is having a blessed Saturday. Having issues with rough Idle on my 3.2 so I pulled it apart and found a few surprises. The drivers side fuel injector harness is damaged, and this sensor is broken where it bolts on. Something is leaking oil also...
Sensor was plugged into Fuel injector harness
Need to know what this part is:
from top to bottom is reads: htc 090704 181104 1 o6e025g
06E906036C
/H
it looks just like the end of one but it is not one of the injector connections. it was, however, connected to the fuel injector wiring harness which has 5 connecting parts on it. 3 for the drivers side fuel injectors and one towards the firewall and one in front of the number 4 fuel injector. This sensor was connected to the fuel injector wiring harness and was sitting under the High pressure fuel pump. Could the high pressure fuel pump possible have a connection that leads to the fuel injector wiring harness??? Anyone have a diagram?
high pressure fuel pump issue solved
The part that had no home ended up being the connector to the end of my high pressure fuel pump aka fuel pressure regulator valve (n276), some how it broke off completely.
https://www.audiworld.com/forums/a6-...e-oil-2891620/
skonstantin
09-03-2012 05:45 AM
host23age
07-02-2011 07:54 PM
