2006 a6 automatic trans fluid
#21
A simple solution to determining what fluid is in my car seems to be to, just, get it jacked up level, warm up the trans a little & pull the fill plug, Then, see what color the fluid is! If the level is too low for any to drain out, I can put my finger in there & see what I get.
Then, I can order a trans filter & oil change kit from Blauparts, be done.
I have (and had) LG8, but I sure couldn't tell that the old fluid was 'blue'
also, correct to sample via the FILL plug---remember engine running when you do this. also, don't drain until you are certain that you can remove the fill plug.
#22
this *might* work for you, but unless you are very experienced in the color of the fluid and subtle tint differences you may end up confused.
i got little confused myself..oil looked different depending on light.. =D see my old post:
https://www.audiworld.com/forums/a6-.../#post24298860
=D
cheers/H
#25
Aren't you glad you didn't just put the LF6, like you were initially going to do...just follow the write-up on the tranny fluid change now, and you'll be fine.
#26
Also.. A scan log on trans would be nice.. =)
You know there are the Lg6 plus atf oil also.. It was factory filled in mine.. =)
Cheers /H
edit: looked in elsa..the new green fluid you must have atleast sw version 0050 and up...(depending what gearbox you have)
mine HLK have 0020 and have the LG6+ blue fluid..
cheers/H
#27
They gave me the VW part number that translates to LG8.
Last night, I ordered 6l of LG8 from bavauto.com. They had the cheapest price, anywhere, under $27/liter shipped. I picked up a filter & gasket off eBay too.
#28
So they just didn't look in etka system.. There is always listed latest oil version.. =)
So make sure you have the right sw in tranny =) (that's why I wanted the log.. To verify it for you =))
Cheers /H
#29
Last week, the display went out on my XP laptop. It's being replaced now. That's where I have my VCDS. So, I cannot access the scan until one get it back from repair, later this week.
At the dealer, in the service dept, they entered my VIN & brought up the theat drivetrain section. From that, they brought up the fluid part number G 060162 A2. I correlated that to LG8.
#30
i read that the green oil is put in from 2008-> ...so in that case your tranny have to been updated...(not very common unless it have had shifting issues)
cheers/H
