A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
2006 A6 avant buyers guide?
Old 06-28-2015, 06:11 AM
16vsilverstreak's Avatar
Default 2006 A6 avant buyers guide?
I'm considering a 2006 A6 avant with 106k miles. It appears by the pictures that it is in good shape. I will be scanning it when I look at it. What problems could this model have, what should I look for? Some of the things I've seen in my search for information, replaced steering column, MMI failure. If you own or have owned this model what have you had to replace that is not normal maintenance? I checked out TrueDelta, small sampling. Thank you.
Old 06-28-2015, 06:36 AM
KevinGary's Avatar
Which engine?
Old 06-28-2015, 07:06 AM
Originally Posted by KevinGary
Which engine?
3.2 V6
Old 06-29-2015, 11:09 PM
A6Gary's Avatar
I have owned a '06 A6 Avant since 9/2008., and now have 74K miles on it. No major problems, except the recent DTC P9404 problem (leak detection pump problem). For the MY 2006 Avant, you should ensure that the TSB for the rear washer hose cracking was implemented on the car you're considering. If not done and the washer fluid leaks, it could cost you a couple of grand to fix (fluid leaks on the electronics in the left rear storage compartment. Other than that, just the regular maintenance items (brakes, brake fluid, tires, replacing TPMS sensors, oil/filter changes, etc.).
Timbo 1959
New Member Welcome Area
07-30-2017 12:06 AM
ajg617
09-29-2013 05:50 AM
A6Gary
09-27-2008 10:27 AM
Pat Kullenberg
Misc. Models Discussion
12-16-1998 06:32 PM
Quick Reply: 2006 A6 avant buyers guide?
