A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
2006 A6 fuel gauge problem
Old 11-22-2009, 12:32 PM
V6UnderPressure's Avatar
Default 2006 A6 fuel gauge problem
I brought my 06 A6 3.2 in for a fuel gauge problem on Friday. The car would go from full tank to zero. They replaced the harness since it was a known problem with our cars and it did not fix the problem. well at least I got a loaner out of the deal. The warranty is up in 1,000 miles. Is there anything that I should have them do b4 it is up? I really should look into an extended warranty.
Old 11-22-2009, 01:27 PM
KevinGary's Avatar
Check my TSB thread with Dr. Cold and you will see that there is a TSB on the fuel gauge seeting forth the repair procedure. Here is the link to the thread with the TSB library https://www.audiworld.com/forums/sho....php?t=2765704
and here is the link to the TSB library itself http://www.uberlame.com/a6_tsb/Audi%...TSB%20List.htm
Old 11-23-2009, 07:26 AM
kemer1's Avatar
Ya what Kevin said...
I had a similar issue where the fuel gauge wouldn't show proper level after fill up and they just updated the software and that fixed it for me.
Old 11-23-2009, 06:41 PM
Cespinal's Avatar
Default I have this.....
same problem and the dealer wants to charge me $725 to swap out my tail lights since I'm not under warranty anymore.
Old 11-23-2009, 06:42 PM
Cespinal's Avatar
Default Oops..
Sorry guys wrong thread!
Old 11-23-2009, 07:16 PM
jazznuts699's Avatar
make sure they check the fuel sending units... as they may be bad as well... had mine replaced since software alone did not fix the problem... same problem. fuel gauge going to 0 or half when it was full... weird stuff... made me 2nd guess myself a couple times... "... did i or did i not get gas yesterday...." hehe
Old 11-24-2009, 06:27 PM
It was on fact the sending units. First they replaced a harness that was in the TSB but that did not work so they had to replace the sending units. Thanks for your help guys.
Old 04-28-2018, 10:50 AM
Lvalle1994's Avatar
You wouldn't happen to have a part number or a link for the parts? thanks for this thread by the way im currently working on my 05 a6 4.2, just a bunch of sensors and small things but so far its been good to me.
gregorydouglas89
A4 (B7 Platform) Discussion
20
11-04-2018 08:21 PM
Galco
54
11-03-2018 02:13 AM
beep-beep
09-23-2015 04:13 PM
ober
09-22-2015 12:06 PM
jk1391
08-31-2015 04:39 AM
Quick Reply: 2006 A6 fuel gauge problem
