A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Problrms engaging reverse.
Old 12-24-2013, 02:41 PM
Infinity_UK's Avatar
Default Problrms engaging reverse.
Hi Everyone,
First of all Merry Christmas!
More problems with my car! I have a 2006 Audi A6 7 speed Auto 2.0 Diesel.
While driving the other day the engine management light came on. Everything seemed fine while driving. I parked up thinking it was glitch hoping the the error would clear by the next day but it did not. The next day I could not put the car in reverse. The gear lever oult not get out of park, so I used the override button near the gear lever and was able to get the car into gear. I managed to get out of my drive, but later on in a car park I tried to reverse into a parking space and put the car in reverse. As I tried to accelarate and the engine just reved and the car hardly moved. After around 5 seconds the beeped into reverse and let me reverse.
I did some testing. I tried to put the car into reverse and sometimes it took a good 5-10 seconds before I heard the reverse beep and the car engaged into reverse. A few times it really clunked/jerked into gear. I seems like I have to put it in gear and wait a bit before trying to reverse.
I managed to get a diag done on the car and it showed the following. I did get the codes cleared thinking it may sort the problem out but it did not:
Address 01: Engine Labels: 038-906-019-AJM.lbl
Part No: 038 906 019 LR
Component: 1,9l R4 EDC G001AG 1565
Coding: 00001
Shop #: WSC 00020
1 Fault Found:
17965 - Charge Pressure Control
P1557 -- 35-10 - Positive Deviation - Intermittent
Readiness: 0 0 X X X
Address 02: Auto Trans Labels: None
Part No: 09B 927 750 L
Component: AG5 Getriebe 09B 0248
1 Fault Found:
00300 - Transmission Fluid Temp. Sensor (G93)
27-10 -- Implausible Signal - Intermittent
After getting the codes cleared and drivng the car for a few day I got another diag done, but nothing showed up as an error, bit I still have the problem.
Any ideas on how to fix this problem?
Thanks
Old 12-26-2013, 11:40 AM
eazy211187's Avatar
It sound like Multitronic(valve body)has a bad solenoid. Or needs to be replaced.
ECS Tuning-Audi
S4 (B8 Platform) Discussion
07-26-2018 02:02 PM
ECS Tuning-Audi
02-04-2016 08:36 AM
levansula
12-10-2015 04:10 PM
antonio007
09-28-2015 12:30 PM
gardandre
09-25-2015 12:24 PM
Quick Reply: Problrms engaging reverse.
