2008 a6 4.2L cylinder 2 misfire
SOLVED 2008 a6 4.2L cylinder 2 misfire
Hi Everyone,
I just picked up a 2008 a6 4.2L with 70k miles about two months ago. About a week ago the car would shake a bit the first start of the day and I started getting 302 cylinder 2 misfire cel. After reading around the forums, I changed the coil and plug on cylinder 2 which seems to have smoothed the engine out a bit, since it doesn't shake after the first start anymore, but when I accelerate a bit harder, the cel blinks, but doesn't always stay on. When it stays on it's that same cylinder 2 misfire.
Ross Tech has shipped my cable and I should hopefully have it in-hand tomorrow, so I can't supply any readings from VCDS yet. Is there any specific things in VCDS that I should look at when I get it that would be the most helpful?
Also I wanted to see if I'm thinking along the correct lines, after reading various threads of similar issues, for fixing this issue...
1. Some point at the MAF, but would this make sense since it's seemingly only affecting one cylinder?
2. Some point out the injector...maybe it's clogged slightly and lean under load?
3. Saw a thread about an Ignition Control Module(ICM) to test the resistance, but I'm having troubles finding it and I don't see a mention of it the the Bentley manual for the car. Any advice on where it might be other that following wires which are all encased in looms?
4. Saw many threads about carbon buildup on the 3.2L engines...does this affect the 4.2L as well?
Thanks in advance for any helpful information you are willing to provide!
My Ross Tech cable arrived today and I ran out to the car to do a scan:
Address 01: Engine Labels: None
Part No SW: 4F1 910 560 E HW: 4F1 907 560
Component: 4.2l V8/4V 0030
Revision: 74H04--- Serial number:
Coding: 01050009190F0120
Shop #: WSC 02120 444 83870
VCID: 2541D09EECAED636C81-8070
2 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 2
Fault Frequency: 6
Reset counter: 255
Mileage: 121522 km
Time Indication: 0
Date: 2014.08.18
Time: 07:38:45
Freeze Frame:
RPM: 2799 /min
Load: 77.6 %
Speed: 59.0 km/h
Temperature: 65.0C
Temperature: 26.0C
Absolute Pres.: 980.0 mbar
Voltage: 14.224 V
000770 - Cylinder 2
P0302 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 255
Mileage: 121522 km
Time Indication: 0
Date: 2014.08.18
Time: 07:38:45
Freeze Frame:
RPM: 2799 /min
Load: 77.6 %
Speed: 59.0 km/h
Temperature: 65.0C
Temperature: 26.0C
Voltage: 14.224 V
Readiness: 0000 0000
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 255
Mileage: 121522 km
Time Indication: 0
Date: 2014.08.18
Time: 07:38:45
Freeze Frame:
RPM: 2799 /min
Load: 77.6 %
Speed: 59.0 km/h
Temperature: 65.0C
Temperature: 26.0C
Voltage: 14.224 V
000770 - Cylinder 2
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 255
Mileage: 121522 km
Time Indication: 0
Date: 2014.08.18
Time: 07:38:45
Freeze Frame:
RPM: 2799 /min
Load: 77.6 %
Speed: 59.0 km/h
Temperature: 65.0C
Temperature: 26.0C
Voltage: 14.224 V
Hi Everyone,
I would also recommend changing out some of the coil packs with another one that you feel is 'good'. Lastly, your year (08) model of 4.2 is an FSI therefore, yes it is susceptible to carbon build-up.
raj99, thanks for giving me some feedback!
This weekend I changed all the spark plugs and coil packs, including a new set in cylinder 2 which i had previously changed, since I had no real maintenance history of the car. Reset all codes and drove around. Seemed fine for the first test run, then later after the car cooled off and I drove again the MIL and EPC indicators came on. The EPC indicator seems to go away after shutting down and restarting the car (kind of like most microsoft o.s.) and doesn't seem to return until the first start of the day or after the car has sat for many hours.
Here's the latest scan, any ideas would be highly appreciated.
Code:
VCDS Version: Release 12.12.2 (x64) Data version: 20140212 Monday,25,August,2014,08:53:26:20432 Chassis Type: 4F (4L0) Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52 53 55 56 61 62 65 72 77 VIN: WAUEV74FX8N091756 Mileage: 122330km/76012miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: Cannot be reached 1100 0F-Digital Radio -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: None Part No SW: 4F1 910 560 E HW: 4F1 907 560 Component: 4.2l V8/4V 0030 Revision: 74H04--- Serial number: Coding: 01050009190F0120 Shop #: WSC 02120 444 83870 VCID: 2541D09EECAED636C81-8070 4 Faults Found: 000768 - Random/Multiple Cylinder Misfire Detected P0300 - 001 - - MIL ON Freeze Frame: Fault Status: 11100001 Fault Priority: 2 Fault Frequency: 6 Reset counter: 255 Mileage: 122161 km Time Indication: 0 Date: 2014.08.23 Time: 15:14:33 Freeze Frame: RPM: 2447 /min Load: 61.5 % Speed: 33.0 km/h Temperature: 50.0C Temperature: 28.0C Absolute Pres.: 980.0 mbar Voltage: 13.716 V 000770 - Cylinder 2 P0302 - 001 - Misfire Detected - MIL ON Freeze Frame: Fault Status: 11100001 Fault Priority: 2 Fault Frequency: 6 Reset counter: 255 Mileage: 122161 km Time Indication: 0 Date: 2014.08.23 Time: 15:14:33 Freeze Frame: RPM: 2447 /min Load: 61.5 % Speed: 33.0 km/h Temperature: 50.0C Temperature: 28.0C Absolute Pres.: 980.0 mbar Voltage: 13.716 V 000816 - Knock Sensor 2 (G66) P0330 - 008 - Malfunction - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 2 Reset counter: 255 Mileage: 122161 km Time Indication: 0 Date: 2014.08.23 Time: 15:14:34 Freeze Frame: RPM: 2105 /min Load: 67.0 % Speed: 37.0 km/h Temperature: 50.0C Temperature: 27.0C Absolute Pres.: 980.0 mbar Voltage: 13.335 V 004874 - Cylinder Disabling P130A - 001 - - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 255 Mileage: 122232 km Time Indication: 0 Date: 2014.08.24 Time: 16:36:35 Freeze Frame: RPM: 3125 /min Load: 96.8 % Speed: 87.0 km/h Temperature: 81.0C Temperature: 30.0C Absolute Pres.: 990.0 mbar Voltage: 13.843 V Readiness: 0000 1100 ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4L0-910-468.lbl Part No SW: 4L0 910 468 A HW: 4L0 907 468 B Component: J533__Gateway H06 0060 Revision: 00H06000 Serial number: 1100B07C038148 Coding: E5D59E77303A0600 Shop #: WSC 02145 785 00200 VCID: 2D5128BEB45EEE76001-8078 1 Fault Found: 02076 - Media Player Position 1 (R118) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 210 Mileage: 122161 km Time Indication: 0 Date: 2014.08.23 Time: 14:30:27
I pulled the connector to the MAF sensor and the engine ran no differently. I changed the fuel filter because I didn't know the history of the vehicle and had run the tank down pretty far several times, but it didn't make a difference.
The P0300 (Random Misfire) and P0302 (Cylinder 2 Misfire) I get frequently, but only when I accelerate harder...if I keep the lead foot at bay, the codes stay away. I haven't seen the P0330(Knock Sensor 2) return.
This weekend, while I change the oil and air filter, I'm thinking about trying a couple things.
1. Soaking the MAF in alcohol to clean it, then putting it back in after it's dry.
2. Using a party fog machine to smoke the vacuum lines to check for a leak.
Anything else that I should try?
I'm getting frustrated with this car...and I've worked on my own vehicles for the last 20+ years. So far the Bently repair manual seems to be far inferior to the Helms manuals that many other brands use.
Soaking the MAF didn't help...or hurt. I'm running out of things to try...tomorrow for the smoke test.
Is there a List of Measure Blocks in the Bentley manual? I'm poking around but haven't found one yet.
Most cylinders had some buildup, but #8 was the worst by far. The valves on #2 were actually amongst the cleanest.
The manifold gasket and cleaning have smoothed out the motor for the most part, but I'm still getting the P0300 and P0302 on the vag com. The other thing I'm still seeing is occasionally on the first startup of the day, the car runs a little rougher and it shows the EPC warning on the instruments. If I restart the car it runs fine. I'm thinking this must be an electronics issue (sensor, ground, etc) and not mechanical since it's intermittent.
I had my vag com with me when the EPC light went on this time. Here's the scan.
The engine codes I see regularly, but not the Can Gateway errors. Maybe they clear when I restart the car after the EPC warning shows up? Any advice for finding the cause of these codes?
Code:
VCDS Version: Release 14.10.0 (x64) Data version: 20141022 Friday,14,November,2014,08:18:36:20432 Chassis Type: 4F (4L0) Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52 53 55 56 61 62 65 72 77 VIN: WAUEV74FX8N091756 Mileage: 131730km-81853miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: OK 0000 0F-Digital Radio -- Status: Malfunction 1010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: Sporadic communication error 1000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: Sporadic communication error 1000 ------------------------------------------------------------------------------- Address 01: Engine Labels: None Part No SW: 4F1 910 560 E HW: 4F1 907 560 Component: 4.2l V8/4V 0030 Revision: 74H04--- Serial number: Coding: 01050009190F0120 Shop #: WSC 02120 444 83870 VCID: 2541D09EECAED6093CD-8070 3 Faults Found: 000768 - Random/Multiple Cylinder Misfire Detected P0300 - 001 - - MIL ON Freeze Frame: Fault Status: 11100001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 131669 km Time Indication: 0 Date: 2014.11.14 Time: 07:05:47 Freeze Frame: RPM: 2368 /min Load: 46.6 % Speed: 49.0 km/h Temperature: 40.0C Temperature: 2.0C Absolute Pres.: 990.0 mbar Voltage: 13.970 V 000770 - Cylinder 2 P0302 - 001 - Misfire Detected - MIL ON Freeze Frame: Fault Status: 11100001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 131669 km Time Indication: 0 Date: 2014.11.14 Time: 07:05:47 Freeze Frame: RPM: 2368 /min Load: 46.6 % Speed: 49.0 km/h Temperature: 40.0C Temperature: 2.0C Absolute Pres.: 990.0 mbar Voltage: 13.970 V 004874 - Cylinder Disabling P130A - 001 - Freeze Frame: Fault Status: 01100001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 255 Mileage: 131669 km Time Indication: 0 Date: 2014.11.14 Time: 07:05:57 Freeze Frame: RPM: 2432 /min Load: 41.2 % Speed: 53.0 km/h Temperature: 42.0C Temperature: 1.0C Absolute Pres.: 990.0 mbar Voltage: 13.970 V Readiness: 0000 1001 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09L-927-760.lbl Part No SW: 4F5 910 156 A HW: 09L 927 156 C Component: AG6 09L 4,2 FSI USA 0010 Revision: --H04--- Serial number: 4404086 Coding: 0000002 Shop #: WSC 02145 785 00200 VCID: 2643D79291A8DD11357-8073 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4F0-910-517.lbl Part No SW: 4F0 910 517 AD HW: 4F0 614 517 AA Component: ESP8 quattro H01 0070 Revision: 00000000 Serial number: 00000000000000 Coding: 0020840 Shop #: WSC 02145 785 00200 VCID: 66C3979251281D11F57-8033 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb Part No SW: 4F0 910 852 A HW: 4F0 905 852 C Component: FBSAUDIC6 ELVSG H01 0040 Revision: 09010701 Serial number: 10601600960375 Coding: 0000003 Shop #: WSC 02145 785 00200 VCID: 2447CD9AE7942F012B3-8071 Subsystem 1 - Part No: 4F0 910 131 J Component: FBSAUDIC6 EZS H45 0080 Subsystem 2 - Part No: 4F0 910 220 A Component: FBSAUDIC6 IDG H01 0040 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl Part No SW: 4F0 910 732 Q HW: 4E0 035 729 Component: Interfacebox H43 4610 Revision: 00000000 Serial number: 303L+077558298 Coding: 0000003 Shop #: WSC 02335 785 00200 VCID: 316934CEA8668AA9D05-8064 Subsystem 1 - Part No: 4F0 910 609 E Component: Bedienteil MMIC6H01 0060 Subsystem 2 - Serial number: 00000002146741 Subsystem 3 - Serial number: 0118.10.130000000100010193 Subsystem 4 - Serial number: 010193 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 4F0-910-043.lbl Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG Component: KLIMABETAETIGUNGH30 0020 Revision: 00000053 Serial number: 00000000475638 Coding: 0532520 Shop #: WSC 02145 785 00200 VCID: 1C37F57ADFE417C1933-8049 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 J HW: 4F0 907 279 A Component: ILM Fahrer H18 0250 Revision: 00000000 Serial number: 4F0907279 Coding: 0113123 Shop #: WSC 02335 785 00200 VCID: 306F31CAA36C83A1DFB-8065 Subsystem 1 - Part No: 4F1 910 113 C Labels: 1KX-955-119.CLB Component: Wischer AudiC6 H05 0210 Coding: 00064784 Shop #: WSC 02335 Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH13 0100 Coding: 00146221 Shop #: WSC 02335 No fault code found. ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 110 E HW: 4E0 035 110 A Component: MP3-Changer H46 0390 Revision: 00046007 Serial number: AUZ5ZBG3514966 Shop #: WSC 00000 000 00000 VCID: 1A3BF362D5D069F181F-804F No fault code found. ------------------------------------------------------------------------------- Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl Part No SW: 4E0 910 593 M HW: 4E0 035 593 F Component: SDAR SIRIUS H07 0160 Revision: 00000000 Serial number: AUZ4Z7G0147266 Coding: 0000100 Shop #: WSC 02323 785 00200 VCID: 316934CEA8668AA9D05-8064 1 Fault Found: 02635 - Tuner Not Enabled/Activated 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 113 Mileage: 131135 km Time Indication: 0 Date: 2014.11.10 Time: 08:47:35 ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4F0-910-655-8R.lbl Part No SW: 4F0 910 655 F HW: 4F0 959 655 A Component: 6N AIRBAG AUDI8RH30 0300 Revision: 15H30000 Serial number: 00359D0GA56O Coding: 0013902 Shop #: WSC 02325 785 00200 VCID: 2A5B23A285B0F97111F-807F Subsystem 1 - Part No: 4F0 910 339 B Component: BF-Gewichtsens. H03 0060 Subsystem 2 - Serial number: 6332CSME371447580 Subsystem 3 - Serial number: 6342CSME37133454Z Subsystem 4 - Serial number: 6352QSME470744519 Subsystem 5 - Serial number: 6362QSME470822618 Subsystem 6 - Serial number: 63734SME46562D194 Subsystem 7 - Serial number: 63834SME4B2F17155 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl Part No SW: 4F0 910 549 A HW: 4F0 953 549 D Component: J0527 0410 Revision: 00H03000 Serial number: 90055073320231 Coding: 0012141 Shop #: WSC 02145 785 00200 VCID: 275DDA9696A2C4190E1-8072 Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 H02 0030 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4F0-910-xxx-17.lbl Part No SW: 4F0 910 930 C HW: 4F0 920 983 Component: KOMBIINSTR. M73 H22 0240 Revision: 00000000 Serial number: 72X55Z4D7 Coding: 2129288 Shop #: WSC 62673 000 1048576 VCID: 2345CE86E29A2839529-8076 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4L0-910-468.lbl Part No SW: 4L0 910 468 A HW: 4L0 907 468 B Component: J533__Gateway H06 0060 Revision: 00H06000 Serial number: 1100B07C038148 Coding: E5D59E77303A0600 Shop #: WSC 02145 785 00200 VCID: 2D5128BEB45EEE49F4D-8078 3 Faults Found: 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 160 Mileage: 131526 km Time Indication: 0 Date: 2014.11.12 Time: 19:36:30 02230 - Digital Radio (DAB) (R147) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 160 Mileage: 131526 km Time Indication: 0 Date: 2014.11.12 Time: 19:45:17 01304 - Radio 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 160 Mileage: 131526 km Time Indication: 0 Date: 2014.11.12 Time: 19:49:35 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4F0 910 760 HW: 4F0 959 760 Component: Sitzmemory FS H04 0050 Revision: 00000000 Serial number: 00000000896400 Coding: 0082946 Shop #: WSC 02145 785 00200 VCID: 61C9848EB8067A29005-8034 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 M HW: 4E0 919 887 M Component: MNS US H51 1100 Revision: 00000000 Serial number: 395L-077507342 Shop #: WSC 44074 001 1048576 VCID: 387F09EA4B1C5BE197B-806D No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl Part No SW: 4F0 910 793 E HW: 4F0 959 793 E Component: TSG FA H12 0210 Revision: 00000000 Serial number: 4 Coding: 0035563 Shop #: WSC 02327 785 00200 VCID: 2C5725BA8F44E741E33-8079 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4F0-910-289.lbl Part No SW: 4F0 910 289 J HW: 4F0 907 289 J Component: Komfortgeraet H26 0210 Revision: 02100026 Serial number: 01083383130000 Coding: 4619293 Shop #: WSC 02335 785 00200 VCID: 316934CEA8668AA9D05-8064 Subsystem 1 - Part No: 1K0 951 605 C Component: LIN BACKUP HORN H03 1301 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4F0-910-223-BO.lbl Part No SW: 4F0 910 223 J HW: 4F0 035 223 G Component: DSP-High C6 H10 0240 Revision: PROD_01 Serial number: 00000000062868 Coding: 0000016 Shop #: WSC 02145 785 00200 VCID: 2541D09EECAED6093CD-8070 No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 C Component: ILM Beifahrer H12 0100 Revision: Serial number: 00000000119441 Coding: 0012014 Shop #: WSC 02145 785 00200 VCID: 5EB3BF72897845D13D7-800B No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl Part No SW: 4F0 910 793 E HW: 4F0 959 792 E Component: TSG BF H12 0210 Revision: 00000000 Serial number: r2 Coding: 0035563 Shop #: WSC 02327 785 00200 VCID: 2C5725BA8F44E741E33-8079 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4F0-910-801.clb Part No SW: 4F0 910 801 C HW: 4F0 907 801 A Component: EPB CDEC0080 H04 0080 Revision: --H04--- Coding: 0007022 Shop #: WSC 02145 785 00200 VCID: 204FC18AF38C33214FB-8075 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4F0-910-357.lbl Part No SW: 4F0 910 357 F HW: 4F0 907 357 F Component: AFS 1 H01 0020 Revision: 00000001 Serial number: Coding: 0000016 Shop #: WSC 02325 785 00200 VCID: 2959DCAE80B6F269185-807C Subsystem 1 - Part No: 4F0 941 329 D Component: AFS-Modul links H01 0010 Subsystem 2 - Part No: 4F0 941 329 D Component: AFS-Modul rechtsH01 0010 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4F0 035 541 L Component: TUNER EU/US/RDW H42 0630 Revision: 00000000 Serial number: 394L-077842233 Coding: 0000002 Shop #: WSC 02145 785 00200 VCID: 316934CEA8668AA9D05-8064 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4F0-910-181.lbl Part No SW: 4F0 910 181 F HW: 4F0 915 181 B Component: J0644 BEM H12 0760 Revision: 00000000 Serial number: 00000000051299 Shop #: WSC 00000 384 00290 VCID: 2447CD9AE7942F012B3-8071 Subsystem 1 - Part No: 4F0 915 105 D Component: von VA0 2711292096 Coding: 344630393135313035442056413032373131323932303936 Shop #: WSC 00000 384 00290 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 E HW: 4F0 959 795 E Component: TSG HL H21 0210 Coding: 0035370 Shop #: WSC 02327 785 00200 VCID: 2E532FB2B9589551CD7-807B No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl Part No SW: 4F0 910 273 B HW: 4F0 907 273 A Component: Reifendruck 3 H05 0100 Revision: 00050100 Serial number: 00000700062629 Coding: 0062422 Shop #: WSC 02145 785 00200 VCID: 224BCB82FD80213159F-8077 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 E HW: 4F0 959 794 E Component: TSG HR H21 0210 Coding: 0035370 Shop #: WSC 02327 785 00200 VCID: 2E532FB2B9589551CD7-807B No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-336.lbl Part No SW: 4F0 910 336 H HW: 4E0 862 335 Component: Handyvorb2 H18 1130 Revision: 00000000 Serial number: 00000005018531 Coding: 0010900 Shop #: WSC 00000 000 00000 VCID: 285FD9AA9BBCCB6107B-807D No fault code found. End-------------------------(Elapsed Time: 02:35)--------------------------
Similar Issue: MY08 C6 A6 4.2 w/ 80K+
Had similar ongoing issues mid-summer.
Started with a mild vibration at idle, then finally it threw a CL with misfires on I believe it was 3, 5, 6. Dealer first replaced all injectors and said they did a cleaning for some carbon build-up. Ran fine for about a week or so, still could feel the vibration at idle.
CL ended up coming on again, this time for misfire on cylinder 2. Dealer took a look and said the intake manifold was leaking... awesome. Replaced the manifold, ran fine for another couple days then CL came on once again.
This time, along with the vibration at idle, it was having issues accelerating... took it back and Dealer switched out the fuel filter. Lo and behold, no more vibration at idle, acceleration came back and all was good.
Hope this may help.
Hope this may help.
