A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
2008 S6 ABS Module
Old 02-21-2014, 09:02 AM
john dillinger's Avatar
Default 2008 S6 ABS Module
hey guys - need to replace (dealer says :static fault any suggestions - ? trying to avoid the 3k charge ,,,,,,,
Old 02-21-2014, 05:57 PM
life4sk8's Avatar
Look with those guys : http://www.bba-reman.com. They can fix your modules.
Old 02-23-2014, 04:33 AM
ericA6's Avatar
I'm in the middle of getting mine repaired through http://www.cheapabs.com. It took me about 45 min to remove the module. I followed the video on his website and it was easy. I haven't received the module in return yet so I'll update when I do and install it back in.
Old 02-23-2014, 05:17 PM
SchwarzS6's Avatar
+1 on bba-reman. I have used them and the service and quality was excellent
Old 02-23-2014, 05:38 PM
raj99's Avatar
I used Module Masters for my previous C5 and they were great. Very quick turnaround...<b>SAME DAY!</b> and the unit lasted for as long as I owned the vehicle.
http://modulemaster.com/en/Audi/A6_info.php
Old 02-26-2014, 06:54 PM
ericA6's Avatar
I got an email back telling me that the work was completed. Not only did he fix the failure points but also redid the points that commonly fail. So far I'm impressed with a one day turnaround and the extra effort to ensure that my module doesn't fail again later! I will update when I get the module installed. It should be in about 3-4 days.
Old 02-27-2014, 11:22 AM
u have an S6 ? Seems like dealing with all the brake lines (bleeding etc) is a pain in the **** no ?
Old 02-27-2014, 11:39 AM
enoch861's Avatar
I don't know about the S6, but on the A6 there is a way to remove the module without bleeding.
Also you can have an Indy remove it for you. Should be less than an hour in labor if they've done it before.
Old 02-27-2014, 11:53 AM
Senior Member
Catamount90's Avatar
Yep... wish I knew about this before I had mine repaired. I pulled the entire unit out.
Check it out:
Old 02-27-2014, 01:35 PM
ericA6's Avatar
I have an A6 3.2Lq. I was able to remove the module without disconnecting any brake lines. Not a big deal at all. Just follow the video posted above. I should get my module back on Fri or Sat. While I was under the hood I fixed a cracked vacuum hose and cleaned the throttle body (it was dirty!). Once I get it all back together I'll clear the codes and do the throttle body adaptation. Hopefully that'll get rid of MIL and the rest of the lights on the dash.
Quick Reply: 2008 S6 ABS Module
