3.2 Chains. Waste of a good Sunday. - AudiWorld Forums
A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007-present
Old 03-30-2014, 03:14 PM   #1
Tech Guru
4Driver4's Avatar
Default 3.2 Chains. Waste of a good Sunday.
Anyone been in this far? Tips for changing chains and resetting timing?
Need to replace a few bank one valves too....oddly, it's bent intake valves.
(Not my car BTW. Doing a favor for a friend.)
4Driver4 is offline   Reply With Quote
Old 03-30-2014, 03:17 PM   #2
Tech Guru
4Driver4's Avatar
Wider shot showing the fancy trans bracket I welded up for the trans jack.
Old 03-30-2014, 03:19 PM   #3
KevinGary's Avatar
Quote:
How did you flip the car upside down? Lol
KevinGary is offline   Reply With Quote
Old 03-30-2014, 03:37 PM   #4
Tech Guru
4Driver4's Avatar
It's levitating. ;-)
Old 03-30-2014, 05:24 PM   #5
KevinGary's Avatar
The dealer has my 4.2 for the chains right now. I am hoping that it is only the guides or the tensioners. I am sure the bill is going to be large. Just hoping that the chains are ok.
Old 03-30-2014, 05:57 PM   #6
What was the problem the owner was having, and how many miles on it?
Mike141 is offline   Reply With Quote
Old 03-30-2014, 06:01 PM   #7
Tech Guru
4Driver4's Avatar
I'm going to do all the chains and guides. Once you get this far, you may as well.
Car was noisy and ran poorly. Bank one cams were in time with each other, but out of time with everything else. Still need to pull the bank one head. Cylinder 1 fails leakdown.
Old 03-30-2014, 07:03 PM   #8
Did you identify any failed parts in the chain guides or tensioners?
SchwarzS6 is offline   Reply With Quote
Old 03-30-2014, 07:10 PM   #9
Tech Guru
4Driver4's Avatar
Nothing obvious yet. The only thing I see is that the main chain tensioner piston retracts very easily. I need to get the oil pump chain off first, but my Bentley PC crashed and I'm not digging deeper without support.
Have I mentioned lately how much I hate Bentley Publishers? They tell you that you should only install on PC's that are stable so you don't risk content loss...but the newest operating system they support goes end of life in a week. Fan-f'ing-tastic.
Old 03-31-2014, 06:31 AM   #10
ProtoFly's Avatar
Quote:
Kevin, when I see that your car also has the problem, I absolutely know that this is a failure in design, not maintenance.
What were the symptoms that made you take it to the dealer?
I finally have all the parts I need to complete mine, and was working on it this weekend. I have about $2000 in parts, including head gaskets, plus my labor. Sent the heads out for resurfacing, etc, new valve seals.
I'm hoping I'm good for another 175k miles, though.
Some of the parts have been redesigned or improved.
For what its worth, although I opted to replace the two upper chains, there was no evidence of stretching. It is the guides which fail, and sometimes the cam adjuster mechanisms.
Based on my non-scientific observation, the passenger side cam chain tensioner seems to be a weak point, as it sheds its plastic, ejecting it into the chain cog. I've noted at least 5 failures on various forums of that.
There will also be a cracked/broken lower guide, but that, I think, only causes the cold start 'rattle'.
Next is the adjusters, which have a locking pin, and the hole that the locking pin goes into gets elongated and then fails to lock.
ProtoFly is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Any "simple" exhaust mods for a bit more rumble ? 2000BEAST Q5/SQ5 MKI (8R) Discussion 9 09-14-2015 08:02 AM
Recs on dash vent clip mobile phone holders Royboy55 A4 (B8 Platform) Discussion 0 09-07-2015 12:07 PM
New/First Audi Owner covertconvert A8 / S8 (D3 Platform) Discussion 0 09-06-2015 01:11 AM
Camshaft Position Sensor Location (3.2 FSi)? irelandbuyer A8 / S8 (D3 Platform) Discussion 2 09-02-2015 07:01 PM
Exhaust and Engine Breakdown leds giuseppepat Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 0 09-02-2015 03:47 AM
Tags
1995, chain, dakota, dodge, replace, timing
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
