A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
45,000 Mile Service
Old 04-03-2009, 05:53 AM
Grey Ghost 3.2's Avatar
Default 45,000 Mile Service
I am going in for my last covered service next week. Is there anything I should mention to have them look at that they would pay to save me from paying for in the future?
Thanks
GG 3.2
Old 04-03-2009, 09:42 AM
Cat Herder
pierreb's Avatar
get a local person to do a vag-com scan and see if you have any codes. for example, only a vag-com scan will tell you if you have an a/c leak before your a/c quits on you.
Old 04-04-2009, 03:24 AM
KevinGary's Avatar
You should have a local mechanic put it up on a lift and do a once over. I did and I discovered slight oil seepage on the back of the valve cover gaskets. I complained to the dealer that I was getting oil drips on the driveway, which I was not. While they said it was hard to believe that the slight seepage was dripping all the way to the driveway, they agreed to change the valve cover gaskets under warranty.
Old 06-28-2009, 04:37 AM
divorce certificate's Avatar
Clean & inspect all brakes, calipers & pads
- Adjust clutch arm travel
- Inspect suspension mounting bolts
- Inspect steering operation, tie-rod ends
steering gear box and boots
- Inspect all brake hoses, lines, cables
- Inspect parking brake and adjust
- Inspect exhaust pipe & muffler
- Inspect power steering system
- Replace radiator coolant
(45,000 miles or once a year-additional $30)
- Check tire pressure
- Inspect tires pressure and wear
- Tire rotation-wheel balance
- Change transmission fluid
- Road test
ccmnova
A4 (B7 Platform) Discussion
10-11-2011 11:24 AM
TPM2002
09-19-2008 09:57 AM
allroad'Ed now
Audi allroad
16
01-13-2006 06:13 PM
magiciansampras
01-31-2003 02:05 PM
Rick
08-24-1999 10:52 AM
Quick Reply: 45,000 Mile Service
