A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Old 07-25-2016, 03:19 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A6 (C5) Brake Guides
Print Wikipost
A6 3.2 Fsi Quattro - ABS Module Recoding?
Old 10-27-2014, 04:13 AM
Solo786's Avatar
Default A6 3.2 Fsi Quattro - ABS Module Recoding?
Hello All,
I am new to this board, and require some very urgent assistance with my A6. I have searched the forums and have found nothing conclusive.
Basically I had the notorious G201 Brake Pressure sensor fail in my abs module. I wasnt aware at the time of services such as BBA Reman & Module Masters at the time, so I purchased a 2nd hand unit on ebay.
My original ABS module part number was 4F0614517L, as inscribed on the hydraulic unit. The part i purchased has the identical part number as well.
I swapped the units out and bled the brakes, only to see a few different trouble codes appear. See here;
Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
Part No SW: 4F1 910 559 C HW: 4F1 907 559
Component: 3.2l V6 FSI 0010
Revision: --H15--- Serial number:
Coding: 01050400190F0120
Shop #: WSC 02325 785 00200
VCID: 2B53BF628AE505461EF-807E
3 Faults Found:
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 43
Reset counter: 193
Mileage: 137799 km
Time Indication: 0
Date: 2014.10.18
Time: 17:08:17
Freeze Frame:
RPM: 1056 /min
Mass Air / Rev.: 130.8 mg/str
Temperature: 42.0°C
Idle
Load: 16.9 %
Speed: 0.0 km/h
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H03 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0020875
Shop #: WSC 02327 785 00200
VCID: 2D57B17AB4F10B7600B-8078
5 Faults Found:
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 39
Reset counter: 207
Mileage: 137799 km
Time Indication: 0
Date: 2014.10.18
Time: 17:42:56
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x47A2
Hex Value: 0x001E
Hex Value: 0x3EAC
Hex Value: 0x00FF
01321 - Control Module for Airbags (J234)
000 - -
Freeze Frame:
Fault Status: 11100000
Fault Priority: 1
Fault Frequency: 38
Reset counter: 207
Mileage: 137799 km
Time Indication: 0
Date: 2014.10.18
Time: 17:45:34
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4782
Hex Value: 0x0014
Hex Value: 0x309C
Hex Value: 0x00FF
01314 - Engine Control Module
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 38
Reset counter: 207
Mileage: 137799 km
Time Indication: 0
Date: 2014.10.18
Time: 17:45:35
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4782
Hex Value: 0x0014
Hex Value: 0x319C
Hex Value: 0x00FF
18055 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 000 -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 37
Reset counter: 207
Mileage: 137799 km
Time Indication: 0
Date: 2014.10.18
Time: 17:45:35
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4782
Hex Value: 0x0014
Hex Value: 0x209C
Hex Value: 0x00FF
01486 - System Function Test Activated
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 36
Reset counter: 207
Mileage: 137799 km
Time Indication: 0
Date: 2014.10.18
Time: 17:49:54
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x47A2
Hex Value: 0x0021
Hex Value: 0x4194
Hex Value: 0x00FF
I have managed to clear the steering angle fault (00778), and the System Function Test (01486)
I cannot clear 18055, 01314, and 01321.
Anyone with any assistance or information on how to do this would be greatly appreciated.
I have mailed the full autoscan to Ross-Tech but I didnt receive any feedback from them - I do own a genuine vag-com hex-can-usb cable purchased from hexdiagnostics south africa. So I am a bit stuck for help.
Old 10-27-2014, 11:22 AM
Solo786's Avatar
Anyone??
Old 10-27-2014, 06:41 PM
jujuC6's Avatar
I would suggest you send you module to get repaired as it is very likely that it is the culprit to your problem. The pump hardly ever goes bad.
Old 10-28-2014, 12:54 AM
Solo786's Avatar
Hey thanks for the response.
So you suggest that I send the replacement part away for repairs??
When i installed the new part, the cruise control started working again and the G201 error went away.
Just these new errors remain - which i think requires some fancy coding changes that I have no idea how to do.
Old 10-29-2014, 09:26 AM
Senior Member
Catamount90's Avatar
OP, that totally stinks. I highly doubt you can recode the new <used> module. If I were in your shoes, I'd have your original module sent out to be repaired. In the meantime, re-list your used module back on eBay. If you're lucky, someone else will buy it.
Otherwise, please see: Audi A6 (4F) Brake Electronics - Ross-Tech Wiki
"Most repair manual sources do not cover this Bosch 8.0 ABS system. When the module is replaced with new it is advised to use the original coding value from the old unit. If this is not possible, registered users can contact us directly with a complete Auto Scan and VIN number."
Old 10-30-2014, 03:59 AM
Solo786's Avatar
I have successfully recoded the module. The trouble was an error on my part for not saving the code before replacing the module. For a 3.2 Quattro with ABS Module 4F0614517L the correct soft coding is 0020895.
The unit i purchased second hand, although identical part number came off a 2.7 tdi quattro - when i plugged it in, somehow that code of 0020875 was identified by the vehicle.
As you can see they are just 1 digit off - being so similar i thought 0020875 was the correct code and I was missing some other steps..
Did some googling and found an auto-scan from another 3.2 with the same part ID and used that soft code.
Now all is resolved, no more xmas tree dashboard and annoying beeps.. I've never been this relieved in my life!
Old 10-30-2014, 04:56 AM
uberwgn's Avatar
Very nice! It's great when you can solve a problem like this
Old 08-18-2018, 01:40 PM
sweetcarguy's Avatar
Default Same Issue
I also purchased a used part from a wrecker. How do I get it to work with my Audi?
briano12
New Member Welcome Area
12-14-2022 03:50 PM
Nalene
05-16-2018 07:34 AM
jeepcj779
08-24-2017 04:31 PM
maciekb2002
02-26-2012 02:41 PM
Dubz Minus 3
VAG-COM Discussion
09-18-2008 03:16 PM
Quick Reply: A6 3.2 Fsi Quattro - ABS Module Recoding?
