GAS GAUGE/BRAKE LIGHTS....HELP!!
Hey Audi Owners: I have had my 2005 A6 for about 2 months. It has 112k miles and it runs great. However, there are a few issues that drive me insane. First, I was getting a notification on my dash that the rear brake light and rear right turn signal were out. So I replaced all the little light bulbs, very tedious, and it still throws a notification sometimes. It always resets when I restart the car and I would say that it goes off once a day or every other day.
The other issue is that I had 1/8 of a tank of gas and when I turned my car on the needle fell to E. I put 3 gallons in the tank immediately and the needle didn't move. I then went to another gas station and just filled up all the way and the needle went back up to Full. Over the weekend, on one occasion, the needle fell to E again but the next morning it was back up.
What should I do? Do I need to replace the bulbs with ONLY Audi bulbs or something? And should I put a cleaner in the tank to clean out any dirt on the sensors?
Help a gal out!!!
Kristine
Help a gal out!!!
Kristine
well hello there, and welcome.
both of these issues you mentioned are pretty common with our cars.
1. the tail light , i believe its your LED strip, which the bulbs are not replaceable without replacing the entire unit. Some have found a way around it by cleaning the connections, running a new wire etc. im not sure how handy are ya and if it will actually be the right remedy.
i had to replace BOTH of mine, they run about $240 each.
2. The fuel tank issue, it happened to me as well a few times, it has been ok for now. keeping my fingers crossed. this is due to a FUEL sender Sensor, in the gas tank. i have not replaced mine yet, but i will have to sooner or later.
there is the link in relation to the fuel tank/ gauge issue.
http://uberlame.com/a6_tsb/Electrica...0refueling.pdf
i am sure others will add more to the situation , but just wanted to briefly shed some light for you.
PC
PC
Thanks for the reply! I have heard a few things and wasn't quite sure what is true and what isn't. As far as the bulbs go, is it true that I need to be buying Audi bulbs that send enough electricity back to the computer instead of generic ones? Replacing the housing sounds expensive so maybe i will try to clean the housing.
As far as the fuel gauge goes, should I try an additive to clean out the system?
The fuel gauge issue is a software issue.
I had exact issues. Good thing I have vagcom. Taillight bulb housing needed to be replaced (not the whole taillight) and that was $60 I believe. Fuel gauge showing empty was the is the sensor on fuel pump. I haven't fixied it yet but all works well so far, but the kit to fix is ~$40 on genuineaudiparts.com
kreativecid
Q5/SQ5 MKI (8R) Discussion
16
10-04-2021 12:30 PM
Monsoonenough
S4 (B8 Platform) Discussion
10-03-2015 02:59 PM
Ray_QT
21
10-02-2015 01:50 AM
