A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Old 09-06-2016, 11:27 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A6 (C6) Exterior Guides
Print Wikipost
A6 (A3, A8) doors not unlocking.
Old 03-10-2015, 01:28 AM
  #11
deezell's Avatar
Originally Posted by haloguy628
Common problem on VAG cars up to I believe 2003? That's when VAG reengineered the microswitches in the latch. Real PITA to change as you have to take apart the whole door interior to get to it.
Edit. The problem I described was on the B5 Passat and B5 A4. Those latches were reengineered. Seems like our cars have the same problem.
Yes, I had the same problem on a 2002 passat, rear door,I sold it with the problem still there, so I wasn't too surprised to see a similar one occurring on the A6. In this case the common fault is not the relay but the motor contact. Locks are expensive, and used ones are scarce, overpriced and probably have the fault or are on the way to it, hence my decision to get to the root of the problem. I've had three show this fault, and it's the same fix in each case. There are three relays also in the lock, one for sensing door closure and the other two sense the motor driven slide interlock positions. It's the failure of the right hand motor to reset it's slide that causes the problem, throws a fault on vcds, "infeasible output" or something like that. Incidentally. If you're wondering how a presumed open circuit motor seems to turn the cam to lock but not to open it, the smaller second motor driving the green slide interlock is connected by slip gearing to the right hand shaft, so though they operate independently on open, they are geared together on lock, hence both shafts turn. If the main motor contacts are partly conducting, you get the intermittent fault, whereby it sometimes has enough torque to unlock, but locking is not a problem due to the second motor.
Old 03-10-2015, 02:10 AM
  #12
royclark's Avatar
Originally Posted by deezell
It helped that I had the old faulty lock to work on. You can buy used locks on ebay, or from a breakers. They might work for years or show this fault eventually, but for 50 quid it's worth a chance, and you have to old lock to play with. Front and back passenger locks are almost identical, just the child proof cam in the back one, but they can be interchanged in a fix.
That's a thought, I could get a used one, check it out as you did above and replace my lock with it.
Then I could repair my lock for a spare.
Old 05-21-2015, 06:42 PM
  #13
first.octopus's Avatar
Front driver side door is having lock issue two weeks ago. It is going to be a weekend project. Do you roll up (or roll down) the window before removing the door panel for easy access to the lock? Thanks.
Old 05-25-2015, 12:26 AM
  #14
deezell's Avatar
Roll up the windows, but access is not that easy as such. You need to unclip the outer door handle rod and as it's driver side, the rod from the key cylinder. Two star bolts from the inner edge, uncouple the power cable from the base of the lock, then drop and turn the lock to let the bowden cable inside. Remove this cable when you have a clear view of it, this will make it possible to remove the lock by turning it upside down the rotating it around the window carrier frame. It can be done, saves having to unbolt and lift out the entire window and carrier frame. I've not done a driver's side, I believe the lock cylinder rod requires special attention to remove, a small sliding clip. It's mentioned on other posts.
Old 05-25-2015, 09:24 AM
  #15
Thanks deezell. This is similar to my problem. It will unlock; but it won't lock. If I try press unlock and then lock with the remote, it will work 8 out of 10 times. But I can lock and unlock using the key. Look like the problem with the main motor does not have enough torque to lock the door.
I scan the car with VAG-COM. The only fault I got was this:
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0210
Revision: 00000000 Serial number: VS
Coding: 0035563
Shop #: WSC 02327 785 00200
VCID: 2C57E2328FAB3A7E18B-8079
1 Fault Found:
02115 - Locking Unit for Central Locking
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 41
Reset counter: 7
Mileage: 121552 km
Time Indication: 0
Date: 2015.05.05
Time: 22:23:52
Old 05-25-2015, 04:11 PM
  #16
deezell's Avatar
Coding: 0035563
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 41
Reset counter: 7
Mileage: 121552 km
Time Indication: 0
Date: 2015.05.05
Time: 22:23:52
This is the same code I got with VAG COM, your problem is the reverse, unlocking but not locking intermittently. This is typical of a poor electrical connection, but perhaps in your case it is the other motor contacts. Only one way to find out, remove the lock, plug back in the cable,take off the cam cover and watch the shafts rotate on lock/unlock. ('close' the lock mechanism with a screwdriver first). It could also be a poor contact on one of the microswitch, but I would bet on a motor contact. At least with the drivers door you can use the key.
Old 10-03-2015, 01:40 PM
  #17
LMSI-G35X's Avatar
What is the part number for this door lock? I need one for the FR door.
Old 10-04-2015, 12:03 AM
  #18
royclark's Avatar
Put your car details in here - Audi - A6 - 2009 Teile Katalog (Pats Catalog)
- to find your part number.
Old 10-04-2015, 12:12 AM
  #19
royclark's Avatar
My passenger door lock has put itself right. What caused mine to go wrong was, the wife tried to open the door at the same time as I unlocked it with the key fob, I think that this threw the lock timing out.
After repeated locking and unlocking it has sorted it self out.
It's been OK for months now.
Look at this - Please Help Tdi sport drivers door won't open from outside - Page 2
Old 10-05-2015, 01:16 AM
  #20
deezell's Avatar
Part no. 4F1837016 Front Right US (passenger) door lock
See here AUDI A6/AVANT [A6] (USA) 2009: BODY: 83730. INNER ACTUATOR; DOOR LOCK
Quick Reply: A6 (A3, A8) doors not unlocking.
