Adaptive lights question on 2005 Audi A6
#21
here's what I'm getting...
firstly, can't connect to 55 - Xenon Range - No response from controller
in 19 - CAN Gateway, I get the following:
Friday,31,May,2013,19:18:28:24415
VCDS Version: Beta 12.10.4 (x64)
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Control Module Part Number: 4L0 910 468 A HW: 4L0 907 468 B
Component and/or Version: J533__Gateway H06 0071
Software Coding: F5D5DEFF707A0608
Work Shop Code: WSC 08143 444 89647
VCID: 2D5BF023B44E6176155
2 Faults Found:
01310 - Level Control System Control Module (J197)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 187
Mileage: 123940 km
Time Indication: 0
Date: 2013.05.31
Time: 19:13:49
01771 - Control Module for Headlight Range (J431)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 187
Mileage: 123940 km
Time Indication: 0
Date: 2013.05.31
Time: 19:16:46
any thoughts?
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 187
Mileage: 123940 km
Time Indication: 0
Date: 2013.05.31
Time: 19:13:49
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 187
Mileage: 123940 km
Time Indication: 0
Date: 2013.05.31
Time: 19:16:46
any thoughts?
#23
I also got the dreaded left motor malfunction error. Where are folks purchasing the headlights from? Aftermarket/OEM? From what I'm reading its recommended to change in pairs to get an even lighting effect.
#24
I still don't have it replaced. Just too expensive for anything I've found. If someone gets a deal on a set and wants the passenger side, I'll go for the driver side.
#25
I had the dealer replace both of my adaptive headlights before I finally gave up on my old car. It does seem to be a problem in our cars as they age.
#26
Just got off the phone with my dealer. As per them, the motor can be replaced without having to replace the entire headlight.
The motor costs $111 and they think it can be replaced in a hour or maybe even half an hour (@$195/hour). A lot better than replacing the entire headlight.
Part number for motor is: 4f0941293A
Here is the error that I am receiving
Address 55: Xenon Range
Control Module Part Number: 4F0 910 357 C
Component and/or Version: AFS 1 H01 0030
Software Coding: 0000016
Work Shop Code: WSC 02325
Additional Info: 4F0941329B AFS-Modul links H02 0020 4F0941329B AFS-Modul
rechtsH02 0020
1 Fault Found
02627 - Dynamic Cornering Light Motor; Left (V318)
010 - Open or Short to Plus - Intermittent
Freeze Frame
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 15
Reset counter: 40
Mileage: 202296 km
Time Indication: 0
Date: 2014.10.03
Time: 18:37:22
rechtsH02 0020
1 Fault Found
Freeze Frame
Fault Priority: 2
Fault Frequency: 15
Reset counter: 40
Mileage: 202296 km
Time Indication: 0
Date: 2014.10.03
Time: 18:37:22
#28
I would love to hear that you had success with this. I don't believe the self-leveling motor is the issue probably even for you. Do your lights move up when you turn the car on? If so, I don't think that's the issue. The issue is turing the light around the corner when you go, which is what I read your error code (the same as mine) to be. I was previously told that I couldn't replace that motor alone, but sure enough, you seem to have found the part and if it works for you, I will definitely do this for me! I have a headlight assembly I think has a good motor with broken clips I suppose I could try.
#29
There are many thin wires in the the headlight assembly, and they are prone to insulation damage or cut due to heat and vibration. I tried to repair wires after dissecting the plastic housing but gave up because insulation of wires crumbled every time I moved them.
I don't recommend used parts since they will fail soon.
This was best price I found.
https://importecautoparts.com/parts/...1%20029%20EK/3
#30
Thanks for the feedback.
I had my dealer check out my lights and he thought it was the motor itself, but it totally could be the wires. For a car of this age it's just not worth the cost. I wish I could just trick the system so it wouldn't flash and beep.
