Anyone successfully turn off Cold Diagnostics?
on their C6 using Vagcom? Was rummaging around and couldn't find it in the modules where I thought it would be.
Cold diagnostics is the bulb check performed after the car is started with the lights off. It pulses specific lighting circuits checking for resistance from the light bulbs in that path. If no resistance is found, it'll trigger a "bulb out" warning. This is different than the bulb check when the lights are on - that is done "hot". The cold diagnostics causes aftermarket LEDs to flash or flicker when they are off - which is the reason I took off the LED license plate lamps I added a couple of years ago. I thought that I might revisit it .
Banned
