Attention C6 Owners experiencing oil leaks from timing chain cover gasket!
#41
ADVICE DAREDEVIL
Daredevil, have you done this DIY? any advice on what to expect? I'll be tackling this during the holidays and any helpful input is greatly needed! TIA..!
#42
2008 Audi A6 Quattro 3.2 timing cover oil leaks
Was just told by Audi mine is leaking from timing chain cover as well quoted $730.00 labour and 80.00 parts how did you make out with diy? please advise considering this as well. Note is there any good pictures and info available for doing this job. It would be very helpful.
#43
I currently have a case in with AOA regarding an oil leak concern. It has been an issue for me for the last 80k miles in which I have been noticing oil residual all over the bottom of the undercarriage and bottom engine cover. On multiple visits I addressed this concern to the dealers and for the most part I was told that what I was seeing was just residual (bunch of BS) however the actual cause was just detected. All the oil has been coming from the rear timing chain cover gaskets and all this time I was always told from the dealers that there was no leaks found. Big problem is that most of us are outside of out warranty and stuck with a rather large repair of around $3 - $4k (primarily labor time of dropping engine and tranny). There is a good chance our 3.2L engines may have a design flaw. At this point Im still waiting to hear back from AOA on how they want to procede with my case. In the meantime any of you who have the 3.2L engine who have or are currently experiencing this same issue, please give your feedback and note your concern. Audi may have been hiding a huge repair that should have been recalled. And its my best guess that since this leaking of oil is not necessarily a "safety" concern they never went forward with a recall because it would involve a lot of repairs and a lot of money out of their pocket.
Hit me up guys.
Thanks
Hit me up guys.
Thanks
Has anyone attempted to reseal this themselves? I was quoted at $750 to do this.
#44
It is not necessary to drop the engine to reseal the timing chain covers, it can be done in the car. I've resealed chain covers on 3.2L a lot and it is a common problem. The covers use sealant not a gasket and over time they start to leak just like any other cover on the cars. Its really not all that different than getting a leak from the cylinder head covers. Over time and depending on the climate around you will determine how long it takes for them to start leaking.
#45
My mechanic reported the same issue to me. I am not noticing any oil leak. My car has 180+k and the oil is still full after 2000 miles. He said the biggest risk is losing oil so I think I will let this go for a while. He too said the only way to replace is to drop the Quattro transmission.
#47
#48
I feel like I can properly chime in on this. Last weekend I got mine resealed via DIY. It absolutely does not require dropping the engine to get the job done. In fact, it should take no more than a 3-4 hours tops. It's fairly straight forward and I followed it via this video(mostly):
#50
TIMING CHAIN COVER GASKET FAILURE
MY WIFES 05 A6 3.2 HAS THE SAME ISSUE. TOOK ME FOREVER TO FIND IT.
I INITIALLY THOUGHT IT WAS VALVE COVER BECAUSE OIL WAS ALL OVER THE PLACE. DONT KNOW HOW LONG ITS BEEN GOING ON BECAUSE THE BOTTOM AERO CAUGHT MOST OF IT. YOU CAN REPLACE IT YOUR SELF HOWEVER IT IS NOT A WEEKEND JOB. I WAS REPLACING THE EXHAUST AND SPOTTED MINE. I JUST WENT AHEAD AND REPLACED THEM. WATCH YOUR KNUCKLES ON THIS ONE FOLKS! ONLY COST YOU A FEW DOLLARS AND TIME. NOT 3 OR 4 Gs.
