A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Audi A6 Adaptive Xenon Headlights Help!
Old 02-18-2012, 03:13 PM
itruly's Avatar
Default Audi A6 Adaptive Xenon Headlights Help!
Hello All, Usually I am able to get answers to all my questions without ever having to raise a question because it's always there however I was unable to search for my current issue.
I have Audi A6 3.0 S-Line TDI on 2006 (06). Keeping a long story short, lets just say, I have damaged headlights and they both need replacing. (I currently have Adaptive Xenon headlights). I've looked far and wide and am unable to find the same headlights with 'Adaptive' functionality (Short of paying ridiculous £££ at the dealers) for a reasonable price. There does seem to be lots of Xenon headlights with 'DRL' (Daylight Running LED) from facelift Audi's on fleebay however none have Adaptive functionality.
I am told the fittings are the same, but can some one please tell me if I can fit them straight on to the car (Considering my last ones had adaptive functionality) or will my car throw up an error? If it does, is there an easier way to do this and use DRL Xenons
Really struggling to find an answer and any help would be greatly appreciated. Thank you in advance.
Old 02-19-2012, 05:27 AM
royclark's Avatar
http://www.ebay.co.uk/itm/09-11-AUDI...item2c60d3c12c
Ask the seller the question.
Old 02-19-2012, 06:01 AM
jeffry's Avatar
Maybe if you have a vagcom you just remove that functionality out if the car. But I bought mys a couples month ago they wasn't with DRL but have the adaptive functionality and only cost me $350.00 dollars OEM
Old 03-01-2012, 01:28 PM
gooch614's Avatar
I have an 08 with Adaptive headlights and it is a module on the side of the headlight body that you should be able to take off your old body and plug into your new headlight body.
Old 03-02-2012, 06:45 AM
bballfreak's Avatar
Default Question on adaptive headlamp failure on 2005 Audi A6
My x-wife barely bumped a car in the front last year, no damage whatsoever to our car, and got this adaptive light failure.
I think the dealer told her that the headlamp needs to be replaced, does that mean the adaptive module is OK?
Here is the VAGCOM diagnosis
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 A HW: 4F0 907 357 A
Component: AFS 1 H03 0010
Revision: 00000001 Serial number:
Coding: 0000016
Shop #: WSC 02325 785 00200
VCID: 244C0DCFE7C0DE3
Part No: 4F0 941 329 A
Component: AFS-Modul links H05 0010
Component: AFS-Modul rechtsH05 0010
1 Fault Found:
02626 - Dynamic Cornering Light Motor; Right (V319)
010 - Open or Short to Plus - MIL ON
Freeze Frame:
Fault Status: 11101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 2
Mileage: 164536 km
Time Indication: 0
Date: 2012.02.25
Time: 18:51:50
Old 03-13-2012, 03:44 AM
05whtaudia6's Avatar
BBallfreak;
I have the same issue but on the left side; wondering if you found the solution? Do you need the whole light assembly or just the control modules?
martinz.zz
11-20-2023 02:10 PM
AudiNike12
01-29-2019 09:06 AM
audiaram
02-27-2017 08:17 AM
jrachuna
4.2 V8 Discussion
09-15-2011 08:14 PM
steveb56
02-11-2005 08:55 AM
Quick Reply: Audi A6 Adaptive Xenon Headlights Help!
