Audi A6 C6 problem
Audi A6 C6 problem
If anyone can tell me what's happening to me problem..ovo only when the car reaches operating temperature .. when it is cold does not appear to me this ..
The only way to know for sure the issue is to pull a vcds log and post it. But I'm guessing you have an issue with your parking brake: sensor, module, or other mechanism that will require a change.
thank you .. I'll try to replace the brake sensor is cheapest to me so I'm gonna row
but can it be to the parking brake if it works great .. either coil or anything .. everything works great .. when you start the car does not light or lights up when you hover over some holes .. hoped the ESP and ABS
You should pull a vcds log and post it... Otherwise all you are doing is guessing and throwing parts and money at a problem
Either you took the photo 11 years ago or you need to set the time and date in your car. It is important to keep the date and time correct because VCDS scans will tell you when a problem occurred - but only if the clock is right.
Thanks for the tip but I can not make the date and time because we do not like what a button to adjust the spilled Coca-Cola ..😀😀
and I though he has a flux capacitor in the trunk. I mean he has had had a flux capacitor.
