Audi A6 C6 problem
#13
#14
Every time I've had that symbol its been the connector to the one of the two rear brake calipers has come loose. Its a pain to work them back on properly because the wiring harness is very short. If you've changed rear brake pads simply moving the caliper around to replace the pads is enough to work the connector loose. One time I simply raised the rear of the car by lifting from the differential center member. That was enough to work one of them loose. Interestingly enough that only happens when I put the car in "Jack Mode". Not sure why.
Phanes97
01-10-2016 10:36 PM
Zephead007
12-18-2005 02:35 PM
