Best brake pads for front replacement 07 A6
#11
Please let us know your results! My '06 has 212K and will be due for brakes soon. The '07 has 122K and appeared to have fresh brakes when I bought it at beginning of year.
#13
yes no problem i am probably going to get Akebono or EBC ref stuff just not sure price doesn't matter others have recommended akebono a lot. i will post back the results once i get the parts ordered thank you very much for all your input
#14
I am using Hawk HPS on my Ford Flex, heavier vehicle than the A6, and am a big fan of them. Depends what you're after. If you want no dust then go with the Akebono. If you want to stop quickly with no warm up time, then my choice is HPS.
#15
Thanks for that review of your experience w/Akebono! As I mentioned previously a very longtime indy AUDI guy had basically told me the same thing. Dust is not an issue for me, the cars are tools not toys. HAWK HPS and AUDI pads are about the same price. I see Bosch Quiet-Cast & TRW for about 1/2 price. Unless someone chimes in about positive experience with either of those I'll probably go with stock.
#16
I replaced OEM with Akebono on the A6 and regret it. They require more pedal pressure and don't respond well even then, especially when cold. They are slightly better after the first few stops. Not for me.
i hear you i thought stock is always better and i put on brand new brakes and and rotors all four of them at 79k and the pads needs replacing at 108k which is odd... So i decided to go with akebono and next time ill go with hawk i hear they are both pretty good. Any how where are you located i would like to get my car looked at by someone who knows their audis i am stuck in Pittsburgh PA yeah stuck...
any how this is what i bought Akebono EUR1111 Front Ceramic Brake Pads | eBay
i got the Akebono EUR1111 Front Ceramic Brake Pads guys hopefully they'll last longer than the stock pads that lasted only 29k with brand new rotors..
#17
Being the odd guy out with the R1 stuff, I figured I'd chime in.
The premium rotors with slots and Posi Quiet ceramic pads. Stock brakes were dusting badly enough that I wished I never had to touch them. One touch and it was time to clean again. Anyhow.. on the new brakes about 400 miles so far and they are fantastic. The stopping power of stock plus. No effort to use them, no fade at high speeds, no noise at all on a dry install.
Like you, I do not treat them nicely. On a Buick Regal I used a similar setup and got 60K from them with the rotors appearing to be new (no ridges no issues). Hopefully I get at least 60K from this set.
#18
#19
Say you are doing 80-130mph and you have to use the brakes to slow down fast. When you press that pedal the friction and heat created is much greater than when you try to stop from 20-50mph.
That excess heat can change how the pads grab and how much they slow you. When you nail the brakes hard at 80-130mph likely..you need to stop and you don't have extra room to play around with brakes not stopping the car. That is what happens with some pads. I'm not that guy. I'd rather the pad grip consistently at all speeds.
#20
hey i went ahead installed the akebonos today believe it or not they are great they are very smooth with effective braking power. By smooth i mean they don't jerk the car to a stop when you press the pedal i like them i am using oem rotors i will try hawk hps next i haven't heard much about Posi but i know they are very reasonable in pricing. I had one question what do you mean by no fade at high speeds i googled it says brake becomes weaker or ineffective at higher temps..
As for no fade, in your normal driving conditions you do most of your braking at lower speed (i.e. under 60 mph). High speeds (greater than 80mph) would be for those of us who have ever raced or tracked vehicles and where brake fade becomes a liability. Consistency of braking is key and everything needs to be precise, when you head into a turn and need to break from 130mph to 50mph, you need to be certain that your pads and rotors will have the same feel and stopping prowess as the first time. This is precisely why race vehicles run slotted rotors, to shave the pads and ensure predictable and consistent response. Also the very same reason why slotted rotors will eat your pads.
