A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Knock when turning wheel.
Old 08-10-2014, 08:07 PM
fe342185's Avatar
Default Knock when turning wheel.
Hi all,
Wondering if anyone knows what can cause a knock when turning the wheel. I notice it more when at slow speed or not moving. Its usually a single knock and happens more often when turning to the right and the road is uneven.
My garage is positioned on a slight grade and I back in. The knock happens everytime I back into the garage.
Thanks all,
Old 08-11-2014, 08:15 AM
MarkTM65's Avatar
At slow speed in those circumstances I'd guess at the power steering pump.
Old 08-11-2014, 03:23 PM
NR04's Avatar
Another possibility would be worn control arm bushings. Check yours for any excessive play (especially the uppers). Audi used fairly soft rubber bushings and they do not last very long.
Old 08-14-2014, 05:53 PM
haloguy628's Avatar
Or it can be the front sway bar link bushings. I had one of the bushings completely gone and it caused pops when turning and going over bumps.
Old 08-16-2014, 07:20 PM
Medic1's Avatar
That is what caused mine. The drivers side failed. Turn the wheel all the way in one direction and take a good look at the end link on that side. It was easy to see tha mine was bad upon visual inspection. They were around $100 apiece IIRC. I swapped that and the sway bar bushings while I was under the car.
Old 08-17-2014, 03:47 PM
SchwarzS6's Avatar
^^ Same here
S6AVANTDRIVER
03-14-2012 05:56 PM
couper83
9
03-31-2008 06:25 PM
mbar
Audi 100 / A6 (C4 Platform)
12-13-2007 07:56 PM
\@Pazmanian Devil@/
12-23-2003 09:44 PM
Quick Reply: Knock when turning wheel.
