Bluetooth Streaming Solution? 05 A6 - AudiWorld Forums
A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007-present
Old 07-16-2014, 08:40 PM   #1
Default Bluetooth Streaming Solution? 05 A6
Hi all,
I know this issue has been discussed at length, and I have dug through pages of threads looking for a solution, but haven't been able to find an adequate answer.
I currently own a 2005 A6. MMI version 07.5.0 0439; navigation was updated with the 2012 DVD refresh. I have built in Bluetooth in the MMI, but as I understand it, that is solely for making calls.
The previous owner installed this Dension Gateway 500 in the glove box. Present is a 30-pin iPod connection, USB, and the little black box.
I tried using hooking up
this 30 pin bluetooth adapter this 30 pin bluetooth adapter
in the glove box, however, it did not work. iPhone connected to it fine, but no output to audio system.
The USB input works for thumb drives with audio on it, but that looks like it. I tried plugging in my phone to the USB to see what would happen, but all I got was a continue charging--disconnected--charging loop.
Any functioning solutions to getting BT audio streaming to work? Any known 30-pin dongles that work with the car/MMI?
Thanks for any help!
Geglamash is offline   Reply With Quote
Old 07-17-2014, 09:35 AM   #2
raj99's Avatar
Quote:
Originally Posted by Geglamash View Post
Hi all,
I tried using hooking up this 30 pin bluetooth adapter in the glove box, however, it did not work. iPhone connected to it fine, but no output to audio system.
Hi Geglamash and welcome to the forum.
Here are my thoughts on your ask. First your MMI s/w is ancient. The latest ver is 46.1.0! Also, the latest nav DVD is 2014...so get updated
As for the BT streaming ask. I too have the Dension 500 and am evaluating getting the following http://www.viseeostore.com/products/...r-wma1000.html if you do a search for this type of A2DP adapter, it's supposed to work with the Dension system and actually be able to stream audio (music) vs. calls only.
Let us know how it works out.
raj99 is online now   Reply With Quote
Old 07-24-2014, 03:02 PM   #3
Thanks for the reply Raj!
I went ahead and bought a 1000 series tune2air and it works perfectly!
Works just as if I plugged my device directly; complete song info and functionality from the wheel for switching songs, etc.
Old 07-24-2014, 03:13 PM   #4
raj99's Avatar
glad to help...enjoy
Old 07-24-2014, 03:51 PM   #5
Do you think that 1000 series tune2air would work with MMI also?
mill3241 is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
2002 A4 3.0 quattro variable length intake manifold broken levansula A4 (B6 Platform) Discussion 20 08-02-2016 07:11 AM
No first gear!? Anyone with the same problem? Newbie glennlindh Audi allroad 44 03-05-2016 01:06 PM
Sluggish Performance Solved - Replaced Intake Manifold Links Galco A8 / S8 (D3 Platform) Discussion 15 10-19-2015 04:56 AM
Audi A8 Mass Air Flow Sensor - Used Projekt 8E Parts For Sale 0 09-28-2015 06:49 PM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
