A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
The 3 year warranty on my car expires in Nov this year. Anyone have the same problems described
Old 08-03-2007, 01:30 AM
ACSGP's Avatar
Default The 3 year warranty on my car expires in Nov this year. Anyone have the same problems described
below, and have they been rectified under a warranty claim?
1. The steering rack has a high intensity juddering noise when parking (ie the steering wheel is being turned 360 degrees or more rapidly), esp when there are high levels of grip on the surface;
2. I've complained repeatedly about the noise made by the electronic parking brake on engagement, esp when the pads are worn; and
3. A-Pillar and Roof Bar Make Cracking Noises : TSB# 2012964 - has anyone gotten this fixed?
4. Smoky exhaust at idle. I've now noticed quite a few C6s at stoplights with the same white smoke at idle.
I'm having the gearbox, transmission damper and suspension bushings changed under warranty. Any other suggestions?
Thanks
Old 08-03-2007, 08:31 AM
coupeboy's Avatar
Default Re: The 3 year warranty on my car expires in Nov this year. Anyone have the same problems described
I get the steering issue you describe when turning the wheel on shiny surfaces like inside parking garages, but never on regular asphalt.
What lead you to get the gearbox and transmission damper and suspension bushings changed?
Old 08-03-2007, 06:25 PM
ACSGP's Avatar
Default The gearbox has a high-piched whine around 60, and the damper
between the box and driveshaft is worn out. This is the 2nd time they're changing it. Probably the way I drive the car, but they should have a more robust product.
Suspension bushing are normal wear and tear items, but the dealer has been doing this for me under warranty since my first 80E in 1995.
Old 08-04-2007, 09:24 PM
New Member
A3A3A3's Avatar
Default Check out this link
This could be the same issue as I have on my allroad<ul><li><a href="https://forums.audiworld.com/allroad/msgs/204556.phtml">https://forums.audiworld.com/allroad/msgs/204556.phtml</a</li></ul>
Old 08-06-2007, 09:41 AM
New Member
idesofmarch's Avatar
re: item 1...I think the manual specifically says lock-to-lock turning of wheel will cause damage?
ks7
A4 (B8 Platform) Discussion
03-10-2017 12:32 PM
madcrazy10
Q5/SQ5 MKI (8R) Discussion
11
06-19-2015 06:04 AM
CessnaDriver
10
04-04-2006 06:10 PM
S6/MCoupeDriver
11-07-2005 10:46 AM
Uncle Castro
10-20-2004 06:08 PM
Quick Reply: The 3 year warranty on my car expires in Nov this year. Anyone have the same problems described
