Can't bleed ABS pump
So I've been working on my mother's car, '05 A6 4.2. Had the ESP and brake light come up and found out the ABS module was bad so I swapped that out. I took out the ABS pump in the process and need to bleed it. Problem is, when I go into VCDS, the Group 002 says not available and I can't bleed the pump.
I've checked what I think are all the possible fuses and don't see any blown ones. I really don't know what it could be. Anyone have any ideas?
Ran a scan and this is what I have. Getting a 01316 error
Sunday,26,June,2016,09:49:30:47399
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
Ross-Tech: Home
VIN: WAUDL74F35N087402 License Plate:
Mileage: 151780km-94311mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 42 46 47 4F 52 53
55 56 61 62 72 76 77
VIN: WAUDL74F35N087402 Mileage: 151780km-94311miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F0 910 560 A HW: 4F0 907 559
Component: 4.2L V8/5V G 0020
Revision: -------- Serial number:
Coding: 0007772
Shop #: WSC 02325 785 00200
VCID: 204F9FFDF37AC43E5E-8074
3 Faults Found:
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - Intermittent
16687 - Cylinder 3
P0303 - 001 - Misfire Detected - Intermittent
Readiness: 0000 0100
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 G HW: 09L 927 156
Component: AG6 09L 4.2L5V USA 0070
Revision: --H01--- Serial number: 0082009
Coding: 0000002
Shop #: WSC 02327 785 00200
VCID: 285F87DD9B4A3C7E16-807C
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H03 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0021352
Shop #: WSC 02331 785 00200
VCID: 2D5176C9B4A81956E5-8078
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 E
Component: FBSAUDIC6 ELV H07 0200
Revision: 00H07000 Serial number: 10603601943680
Coding: 0000011
Shop #: WSC 57365 000 1048576
VCID: 25418EE9EC5821162D-8070
Subsystem 1 - Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H43 0070
Subsystem 2 - Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H36 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 732 Q HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 360LO047513119
Coding: 0000003
VCID: 31696AB9A8907DB6C1-8064
Subsystem 1 - Part No: 4F0 910 609
Component: Bedienteil MMIC6H07 0870
Subsystem 2 - Serial number: 00000000090623
Subsystem 3 - Serial number: 0109.12.040000000100010010ÿ
Subsystem 4 - Serial number: 010010ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F1 820 043 J
Component: KLIMABETAETIGUNGH11 0110
Revision: 00000024 Serial number: 00000000097050
Coding: 0008232
VCID: 5BB5E8119A9CA7E64B-800E
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 AE HW: 4F0 907 279 A
Component: ILM Fahrer H30 0390
Revision: 00000000 Serial number: 4F0907279
Coding: 0112123
Shop #: WSC 03301 444 85755
VCID: 6CD7BBCD4F32D05EB2-8038
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 03301
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 03301
1 Fault Found:
01494 - Bulb for Parking Lamps; Left (M1)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00111011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 55
Mileage: 139644 km
Time Indication: 0
Date: 2015.05.29
Time: 23:28:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBD7105236
Shop #: WSC 00000 000 00000
VCID: 1C37AB0DDF12E0DE82-8048
Address 0F: Digital Radio Labels: 4E0-910-593-XM.lbl
Part No SW: 4E0 910 593 G HW: 4E0 035 593 C
Component: SDAR XM H04 0670
Revision: 00000000 Serial number: AUZ4Z7D8022745
VCID: 2B5578D18ABC1766FB-807E
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 250
Mileage: 150804 km
Time Indication: 0
Date: 2016.05.05
Time: 08:24:08
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 B HW: 4F0 959 655 A
Component: 56 AIRBAG AUDI8RH29 0310
Revision: 10H29000 Serial number: 00359D0850TT
Coding: 0013622
Shop #: WSC 03301 444 68342
VCID: 264389E5915E2A0E24-8072
Subsystem 1 - Part No: 4F0 910 339
Component: BF-Gewichtsens. 002 0040
Subsystem 2 - Serial number: 6332CSME077C341FA
Subsystem 3 - Serial number: 6342CSME081B4543+
Subsystem 4 - Serial number: 6351HSME0F365467D
Subsystem 5 - Serial number: 6361HSME057D006DC
Subsystem 6 - Serial number: 6371VSME0537467CR
Subsystem 7 - Serial number: 6381VSME050C4342E
1 Fault Found:
00588 - Airbag Igniter; Driver Side (N95)
002 - Lower Limit Exceeded - Intermittent - MIL ON
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 B
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90025042220048
Coding: 0012241
Shop #: WSC 03301 444 53325
VCID: 66C3C9E551DEEA0EE4-8032
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H06 0080
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 950 M
Component: KOMBIINSTR. M73 H10 0570
Revision: 00200000 Serial number: 4R871CFD4
Coding: 0065263
Shop #: WSC 01467 002 1048576
VCID: 1E33A105C90EF2CE6C-804A
Address 19: CAN Gateway Labels: 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
Component: Gateway H09 0030
Revision: 09 Serial number: 0800804C1003A2
Coding: ECFE73CC1B1904
VCID: 275D84E1965433061F-8072
1 Fault Found:
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 54
Mileage: 151762 km
Time Indication: 0
Date: 2016.05.31
Time: 13:41:32
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082946
VCID: 61C9DAF9B8F08D3611-8034
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H10 0020
Revision: 00000000 Serial number: ‰d8
Coding: 0035563
VCID: 295982D98040057609-807C
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
Component: Komfortgeraet H14 0090
Revision: 00900014 Serial number: 01002072110000
Coding: 0425021
Shop #: WSC 02335 785 00200
VCID: 2C577BCD8FB2105EF2-8078
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
2 Faults Found:
01506 - Bulb for Rear Fog; Right (L47)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 2
Reset counter: 55
Mileage: 143976 km
Time Indication: 0
Date: 2015.07.24
Time: 07:59:50
01502 - Bulb for Rear Fog; Left (L46)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 55
Mileage: 143976 km
Time Indication: 0
Date: 2015.07.24
Time: 07:59:53
Address 47: Sound System Labels: None
Part No SW: 4F5 910 223 F HW: 4F5 035 223 E
Component: DSP-High C6 H14 0330
Revision: PROD_01 Serial number: 00000000019244
Coding: 0000016
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H09 0050
Revision: Serial number: 00000000054330
Coding: 0011114
Shop #: WSC 02323 785 00200
VCID: 5EB3E105898EB2CE2C-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H10 0020
Revision: 00000000 Serial number: 78
Coding: 0035563
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 D HW: 4F0 907 801 B
Component: EPB CEFC0090 H05 0090
Revision: --H05---
Coding: 0006022
VCID: 21499AF9F870CD3651-8074
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 112
Reset counter: 57
Mileage: 151616 km
Time Indication: 0
Date: 2016.05.21
Time: 17:25:14
Freeze Frame:
Voltage: 13.46 V
Count: 236
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000016
Subsystem 1 - Part No: 4F0 941 329 A
Component: AFS-Modul links H05 0010
Subsystem 2 - Part No: 4F0 941 329 A
Component: AFS-Modul rechtsH05 0010
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 394LX047509413
Coding: 0000002
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0470
Revision: 00000000 Serial number: 00000000093547
VCID: 234590F1E26CDF2643-8076
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 1501120759
Coding: 344630393135313035442056413031353031313230373539
Shop #: WSC 00000 384 00290
1 Fault Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 57
Mileage: 151781 km
Time Indication: 0
Date: 2016.06.19
Time: 17:03:03
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 795
Component: TSG HL H09 0010
Coding: 0035370
VCID: 69D9C2D940C0C576C9-803C
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 794
Component: TSG HR H09 0010
Coding: 0035370
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 HW: 4F0 919 283
Component: Parkhilfe 4-Kan H09 0030
Revision: --.--.-- Serial number: 11720431503678
Coding: 0001206
Shop #: WSC 131071 1023 2097151
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H10 1130
Revision: 00000000 Serial number: 00000007511195
Coding: 0010900
End-------------------------(Elapsed Time: 02:29)--------------------------
Ross-Tech: Home
Coding: 0007772
3 Faults Found:
16687 - Cylinder 3
Coding: 0000002
Coding: 0021352
Coding: 0000011
Coding: 0000003
Coding: 0008232
Coding: 0112123
Coding: 00062736
Shop #: WSC 03301
Coding: 00141886
Shop #: WSC 03301
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 55
Mileage: 139644 km
Time Indication: 0
Date: 2015.05.29
Time: 23:28:00
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 250
Mileage: 150804 km
Time Indication: 0
Date: 2016.05.05
Time: 08:24:08
Coding: 0013622
1 Fault Found:
Coding: 0012241
Coding: 0065263
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 54
Mileage: 151762 km
Time Indication: 0
Date: 2016.05.31
Time: 13:41:32
Coding: 0082946
Coding: 0035563
Coding: 0425021
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 55
Mileage: 143976 km
Time Indication: 0
Date: 2015.07.24
Time: 07:59:50
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 55
Mileage: 143976 km
Time Indication: 0
Date: 2015.07.24
Time: 07:59:53
Coding: 0000016
Coding: 0011114
Coding: 0035563
Revision: --H05---
Coding: 0006022
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 57
Mileage: 151616 km
Time Indication: 0
Date: 2016.05.21
Time: 17:25:14
Freeze Frame:
Voltage: 13.46 V
Count: 236
Coding: 0000016
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 57
Mileage: 151781 km
Time Indication: 0
Date: 2016.06.19
Time: 17:03:03
Coding: 0035370
Coding: 0035370
Coding: 0001206
Coding: 0010900
Cleared all the codes, as far as the brakes are concerned it is only showing 01486 in the ABS module but I still get the not available message for group 002 to bleed the pump.
Mariusz Czarnota
39
04-10-2023 05:37 PM
NPKR
Q7 MKII Discussion
06-29-2016 07:10 AM
Alexanderkeith
05-03-2016 01:34 PM
cbutilier
A4 (B8 Platform) Discussion
05-03-2016 01:14 PM
azaudi1hundo
Audi 100 / A6 (C4 Platform)
04-11-2016 06:24 AM
