A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Center display starts after few minutes when cold
Old 01-16-2017, 08:57 AM
anikon's Avatar
Default Center display starts after few minutes when cold
Hi
On my 2006 Audi A6, the center display starts slow when cold outside(it takes 1-2-3 minutes, depending how cold it is here in South Florida ). I noticed it happens in the morning only. In summer (or over 80F) it comes on normal. Is it hard to replace or fix? What is the part number?
Thanks
Old 01-16-2017, 10:49 AM
raj99's Avatar
Originally Posted by anikon
Hi
Thanks
Before you start throwing parts at the problem take a look at getting a full diagnostic log via a vcds Ross-Tech cable and that should give you additional insight.
Old 01-19-2017, 09:34 AM
ingelstrada's Avatar
Mine starts with a delay in cold weather, too. But more like sub-zero temperatures, not 80F
Old 01-21-2017, 07:44 AM
tekjunkey's Avatar
have seen it in my 2006 A6 and 2008 A6.....but only when the temp drop below 25F....so really cold.
Also, as per my other thread and not sure if related...my display just stopped working altogether this month....
Old 03-14-2018, 06:15 PM
anikon's Avatar
I found a new console at a U pull it yard for 30 bucks. Not sure if it works as is or needs to be reprogrammed.
Old 03-07-2019, 04:29 PM
anikon's Avatar
Default digital display portion of the instrument cluster
I finally found some time to replace the the instrument cluster with the one I got from an accidented A6. The car starts but the digital display shows SAFE now. I also noticed the mileage is 165k, and not 80k I currently have. I assume the instrument cluster stored the car mileage. Can it be reset to the current mileage?
also, how do I get rid of the SAFE and other various lights which are ON on the new display?
I put back my old display until I figure it out, but any help is really appreciated.
thanks
Old 03-08-2019, 02:25 AM
hrc4u's Avatar
SAFE means component protection active.
Go to Audi dealer to get it fixed.
/H
Old 03-09-2019, 09:07 AM
anikon's Avatar
thanks
I put back the old one and now it seems to work fine.
I switched the display between the 2 units and both displays work fine. I noticed one display (older one 2006) has 3 pins and the newer one (2008) only 2. Most likely the issue is not the display but the computer / capacitor that controls the display.
after I installed all parts back I have no air from the center vents. Initially there was no air from the driver vent as well, but it came back once I activated the Econ mode. Center vents still don’t work. I double checked if I connected all wires. this worked fine before I removed it.
how can I reset the AC without a VAGCOM? Do you thing this might help?
thanks
Old 03-11-2019, 12:53 AM
mkv
mkv's Avatar
You have this problem: link
It's a cheap fix when you have to two components, and if you're able to get the soldering done yourself or by someone else.
Old 01-17-2021, 02:29 PM
anikon's Avatar
Thanks. I tried to replace the bad one from my board with another one from another board, but unfortunately i broke one of the pins while removing the good one. I got a new board junk yard and I'll try again. Hopefully i make it this time.
Alex Srbljan
12-21-2016 06:46 AM
NoFlyZnAudi
05-27-2005 08:36 AM
Ged
15
11-01-2002 07:54 AM
Jack-san
04-21-2001 06:05 PM
Quick Reply: Center display starts after few minutes when cold
