crankshaft position sensor vcds code help needed
Hi all,
I am getting the following faults, any help would be highly appreciated:
Address 01: Engine (CCA) Labels: None
Part No SW: 4F1 910 551 D HW: 4F1 907 551
Component: 3.0l V6 TFSI 0030
Revision: --H07--- Serial number:
Coding: 0105000A190F0120
Shop #: WSC 02325 785 00200
VCID: 2447A7D4E7730E1E12-8070
1 Fault Found:
000821 - Crankshaft Position Sensor (G28)
P0335 - 000 - Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 255
Mileage: 117607 km
Time Indication: 0
Date: 2015.08.15
Time: 11:04:35
Freeze Frame:
RPM: 0 /min
Mass Air / Rev.: 0.0 mg/str
Temperature: 27.0°C
Bin. Bits: 00000000
Bin. Bits: 00000001
Speed: 0.0 km/h
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F9 910 156 A HW: 09L 927 156 C
Component: AG6 09L 3,0TFSI USA 0020
Revision: --H05--- Serial number: 4603408
Coding: 0000002
VCID: 2A5B49EC8557D86E28-807E
1 Fault Found:
005913 - Functionality limited due to Engine Control Module
P1719 - 002 - - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 117607 km
Time Indication: 0
Date: 2015.08.15
Time: 11:04:36
Thanks,
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 255
Mileage: 117607 km
Time Indication: 0
Date: 2015.08.15
Time: 11:04:35
Freeze Frame:
RPM: 0 /min
Temperature: 27.0°C
Bin. Bits: 00000000
Bin. Bits: 00000001
Speed: 0.0 km/h
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 117607 km
Time Indication: 0
Date: 2015.08.15
Time: 11:04:36
Thanks,
Distinct
09-13-2004 03:15 AM
