Differential Failure
I have a 2007 A6 quattro 3.2l 6 sp auto US market vehicle and my indy mechanic just informed me that the differential just blew! If i get a used one how do i know if the ratio is the same as the one in there since it is quattro and it would not be good if it was different?
I can not see myself paying about $3,000 plus labor for a new one from Audi, but do not want to spend money on labor for the install and have the wrong one.
I have had other Audis, quattros and they had no drive train problems even after 200K miles and this one only has 114K.
Any help would be appreciated.
Thanks!
Thanks!
Check where the spare tire is at, there should be a label with codes. Something like this.
Look for a code like one of the following: HCC, HNL, HUP - this for the rear differential.
But like 4Driver4 said which differential?
A6 diff blown
Does anyone know if this TSB applies to my vehicle:
http://uberlame.com/a6_tsb/Transmission/Whining noises from rear axle.pdf
can't get the hyperlink to work above this is the name of the TSB:
Whining noises from rear axle (01R)
39 08 03 2017932/1 June 12, 2008
my car is at the indy shop right now, but when i called the Audi dealer, and after giving them my VIN they said i have the HCC code for my rear diff, however the Sticker in the trunk and the diff says HUP, so they did not have accurate info. Hope this helps.
Also how many miles are on the diff you have?
Thanks, but i have a HUP diff. Checking the junk yards, got one in but sent me the wrong one, and everyone is trying to sell me the same type i got wrong so will need to get pics before they send me one from now on.
There Interchangeable, there both 3.10 ratio
HUP should be the updated version from 2007-08
HCC should be from 2005-08
Here's HUP on ebay:
Audi A4 B7 Cabriolet 2 0 Rear Axle Diff Differential Code HUP | eBay
Here's HUP on ebay:
hawaiiguy
02-06-2012 10:34 AM
Houpty
Audi 100 / A6 (C4 Platform)
02-01-2004 09:41 AM
watercooler
04-19-2001 03:54 AM
