How do I remove / install this rubber window seal?
If you look closely, you can see that a section of the outer rubber window seal tore off. I believe that the part number is 4F0837477A.
I'd like to replace this part, but I'm not sure how to remove or install it. I'm guessing it will involve removing the inner door trim/panel, but I haven't been able to find any instructions for removal or installation of this part.
Any help is much appreciated!
If I remember correctly, you have to remove the door glass, and you can access that piece, from the inside where the glass used to be. I replaced the window regulator on the front door many years ago, and pretty sure this is how it comes off.
The door glass will come off in a large assembly, many vids on the tube about this.
Neo1130
07-20-2007 03:44 AM
meem
12-31-2004 01:59 PM
stevestt
04-27-2001 04:47 PM
