A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Old 09-06-2016, 11:27 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A6 (C6) Exterior Guides
Print Wikipost
Door Does Not Open and Stays Locked
Old 06-20-2012, 04:40 AM
jujuC6's Avatar
Default Door Does Not Open and Stays Locked
My car started doing something very strange lately. When I unlock all of the doors the rear driver stays locked and does not open from outside. I have tried everything but I have not been able to figure out what is causing this. Has anyone had this problem and how did you fix it? Thank you.
Old 07-07-2012, 07:34 PM
jujuC6's Avatar
Really, only I got this?
Old 07-08-2012, 01:31 AM
Alister's Avatar
Whilst this may sound pretty strange, have you recently replaced the battery?
Aftermarket batteries can cause some wacky issues with these cars.
Old 07-08-2012, 04:03 AM
uberwgn's Avatar
No, Juju, our 2006 car does the same frequently. Only on the passenger side (rear). I have no idea what's causing it and have not been able to correct it.
Old 07-08-2012, 06:59 AM
jujuC6's Avatar
I did replace the battery with after an after market one but that was about two years ago. I do not think the aftermarket battery if causing this. But now that you mention this I will have the battery tested to rule it out.
Old 07-08-2012, 07:03 AM
jujuC6's Avatar
I wonder if the module that controls the locks is going bad and needs replacing? I have Vag the car and it came back with nothing. Very strange.
Old 07-09-2012, 12:55 PM
revangel's Avatar
i have the same issue with my left-rear door. unable to open/unlock from the outside, but i'm able to open it from the inside so i'm not sure if it's exactly the same issue as yours.
i have the keyless entry and i have read in other posts that the door handle itself will need to be replaced to address this issue.
vag-com result from my vehicle is as follows:
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0051754
Shop #: WSC 02335 785 00200
VCID: 2E591B7AB90C649
1 Fault Found:
02115 - Locking Unit for Central Locking
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 22
Reset counter: 128
Mileage: 52905 km
Time Indication: 0
Date: 2012.03.24
Time: 15:48:36
Old 07-09-2012, 03:37 PM
Alister's Avatar
Well I have a spare door locking module for the front LH door (passenger side in RHD) if anyone would like to purchase it, as I had the same code and some issues with the operation.
Tried replacing the part with the new part, which didn't fix it. Replaced the battery with a genuine item (and coded it appropriately in the battery management system) and all good!
Don't ask me how/why exactly, but it fixed it!
Old 07-09-2012, 05:30 PM
jujuC6's Avatar
Coding: 0051754
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 22
Reset counter: 128
Mileage: 52905 km
Time Indication: 0
Date: 2012.03.24
Time: 15:48:36
Yup, driver rear opens from inside not outside.
Old 07-09-2012, 05:32 PM
jujuC6's Avatar
Really!!! I will try recoding my battery this weekend even though I replaced it two years ago and hope that fixes it.
Quick Reply: Door Does Not Open and Stays Locked
