Last edit by: IB Advertising
- Audi A6 C6 Door Not Unlocking Diagnostic<br>Guide to diagnose trouble and recommended solutions.
Door Does Not Open and Stays Locked
#11
must be something to this 'battery' recoding trick.
here's another output identifying 5 faults found on 'Battery Regul.'
jujuC6, care to share how one goes about recoding the battery? i want to take shot at it if it's not too complicated. otherwise, i will have the stealership do it for me.
thanks in advance.
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000127224
Shop #: WSC 22198 444 59004
VCID: 234FFA4EE2CED91
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2610062184
Coding: 344630393135313035442056413032363130303632313834
Shop #: WSC 00000 384 00290
5 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 11
Mileage: 40069 km
Time Indication: 0
Date: 2010.11.15
Time: 14:24:07
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Mileage: 1048575 km
Time Indication: 0
Date: 2010.11.15
Time: 14:39:29
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Mileage: 40937 km
Time Indication: 0
Date: 2011.01.03
Time: 14:27:23
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Mileage: 40937 km
Time Indication: 0
Date: 2011.01.03
Time: 14:27:33
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Mileage: 40937 km
Time Indication: 0
Date: 2011.01.03
Time: 14:27:43
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0051754
Shop #: WSC 02335 785 00200
VCID: 2E591B7AB90C649
1 Fault Found:
02115 - Locking Unit for Central Locking
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 22
Reset counter: 128
Mileage: 52905 km
Time Indication: 0
Date: 2012.03.24
Time: 15:48:36
thanks in advance.
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 11
Mileage: 40069 km
Time Indication: 0
Date: 2010.11.15
Time: 14:24:07
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Mileage: 1048575 km
Time Indication: 0
Date: 2010.11.15
Time: 14:39:29
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Mileage: 40937 km
Time Indication: 0
Date: 2011.01.03
Time: 14:27:23
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Mileage: 40937 km
Time Indication: 0
Date: 2011.01.03
Time: 14:27:33
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Mileage: 40937 km
Time Indication: 0
Date: 2011.01.03
Time: 14:27:43
Coding: 0051754
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 22
Reset counter: 128
Mileage: 52905 km
Time Indication: 0
Date: 2012.03.24
Time: 15:48:36
#12
I actually did not have any time to that this weekend. But you can try it out with this procedure.
http://wiki.ross-tech.com/wiki/index...ry_Replacement
#15
Cheers!
#16
Two days ago my 2008 Audi Q5 started with this problem. My left rear door doesn't unlock from outside, but open normally by inside. I got the same fault:
Address 62: Door, Rear Left Labels: 4F0-959-795.clb
Control Module Part Number: 4F0 959 795 M HW: 8K0 959 795 B
Component and/or Version: TSG HL H10 0251
Software Coding: 010C02204000240004
Work Shop Code: WSC 06335 000 00000
VCID: 438F3EA8C28EC76
1 Fault Found:
Anyone solved this?
1 Fault Found:
Anyone solved this?
#18
I'm now experiencing this issue on my 2009 Q5, but it's the drivers door (RHD) which is affected, so it's causing me some grief.
Has anyone got any view on how to troubleshoot whether the battery is the root cause, or whether its a microswitch or the lock unit or control unit?
#19
door lock assembly Q5
k2exoman
11-09-2006 04:03 AM
DerTT
19
02-16-2006 07:01 AM
