A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
2006 A6 Drivers Window Switch Replacement
Old 09-02-2011, 06:35 AM
micho69's Avatar
Default 2006 A6 Drivers Window Switch Replacement
I need to replace the master window switch. Most directions that I've seen says it pops if I insert screwdriver into small hole under the armrest but that would not work on my version (see pics).
Does anyone know how to get to the switch? If I have to remove the door panel can anyone provide instructions?
Thanks in advance
Old 09-02-2011, 01:23 PM
dish90's Avatar
I have done this on my A6. Quite an easy job. You will need to remove the door card yes (well i did in my case anywho). If I can remember right:
1. Remove the seal around the door.
2. Remove the wooden trim. Peel it from the back was where I found it easiest. Careful not to break the clips holding it in place
3. Remove the screw/screws (not sure how many hold it here).
4. Start tugging the door card. I started from the bottom and start pulling toward you to loosen the door from the clips. Work your way around the entire door card. When you have the door card all unclipped, lift up the way to remove the top part from under the window.
5. When door card is removed, unclip all wires.
6. Now you need to remove the handle part from the door card. Several screws hold this on. So just have a look around for screws and that should looen it.
7. This should enable you to remove the switch and make the change.
Thats what i can remember. If you have any further issues I can look properly for you so drop me a PM if you wish. Hope this helps.
Old 09-02-2011, 01:24 PM
dish90's Avatar
NOTE: you only need to remove the lower half of the seal. I cant edit the post to fix this.
Old 08-27-2012, 05:02 PM
callahoohoo's Avatar
Do you know if this is the same lock switch as the A4?
andyb64
57
12-13-2023 05:03 PM
Rimshot
10-18-2017 07:11 AM
9audia65
Audi 100 / A6 (C4 Platform)
04-01-2006 10:49 AM
Turhan
04-10-2003 02:25 AM
Quick Reply: 2006 A6 Drivers Window Switch Replacement
