Dusl Mass Flywheel Replacement??
#11
No CVTs do not use a dual mass flywheel. And I too was pretty sure multitronic was referring to CVT transmission. Im not terribly familiar with the DSG transmissions but they do seem to have a DMF. Although they are better known for the mechatronic control unit failure. DMF failure on any of these cars is very rare. yet to have a failed one come through my shop and they have been putting them in Audi's since the 100's w/ 2.8 engines.
#12
Says who??? CVT boxes do use Dual-Mass Flywheel since they are controlled by 'clutch packs'. I just had mine replaced.
Actual part# for my car (US model)...
Flywheel. #06D105317A
CVT Flywheel Flexplate 06D105317A Audi A4 04 05 06 07 08 B7 2 0L At | eBay
other versions, such as the UK...
AUDI A4 A6 EXEO 1.9 2.0 TDI DUAL MASS FLYWHEEL CVT AUTO 038105317 03G 105 317 | eBay
#13
Wrong. All engines have flywheels, otherwise they would not run. Not all engines have dual mass flywheels.
#14
DMF failure
Did you only change the DMF or did you need to change anything else too such as a clutch? I’ve taken mine to two garages and they are saying if I change the DMF, then I need to change the clutch too. The drive is absolutely fine, I only get a rattle when starting the engine.
