A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
hitch on '06 A6
Old 05-19-2014, 01:15 PM
  #11
dknj's Avatar
Hi All,
I'm still trying to get the wiring set for the hitch. The tail lights on my '06 A6 are LED, which may be different then the 2005?
Does that make a difference as far as the taillight converter is concerned?
Thanks!
Old 05-26-2014, 10:00 AM
  #12
hermanesfd's Avatar
Originally Posted by dknj
Hi All,
Thanks!
No it does not, get the normal converter and it will work. You just have to make sure you connect the correct wires. On my converter you don't end up using the brake wire because the blinker wire acts as brakes because the led taillights act as both break lights and blinkers for the car
Old 05-26-2014, 10:11 AM
  #13
KevinGary's Avatar
Hi All,
Thanks!
2005 is also LED
Old 06-02-2014, 08:08 AM
  #14
dknj's Avatar
Just so I am clear, is the following correct?
1. Connect one turn signal from the car to a turn signal wire on the converter
2. Connect the other turn signal from the car to a turn signal wire on the converter and also to the running lights wire.
3. Dont use the brake light wire / ground it out.
4. Connect power wire from the converter to the 12V battery.
Old 06-02-2014, 05:54 PM
  #15
hermanesfd's Avatar
Everything looks good except for #2. You can not use the turn signal wire for the running light wire. If you do this you'll only have the lights when the blinker is on. The running light wire needs to be connected to the lights below the blinker (non led) so it will get constant power so the running lights will work regardless of if the blinkers on or not.
Old 06-02-2014, 07:03 PM
  #16
red rabbit racer's Avatar
i have been flat towing a vw golf chumpcar behind my 2006 A6 4.2 for 4 years 200-300 km per trip without any major problems other than the tow lights occasionally malfunction at night - one side or both running lights go off. doesn't appear to be a bad wiring connection and I thought it might be the additional load above the usual LEDs at night. everything works fine again when the tow lights are disconnected.
Old 06-05-2014, 07:30 AM
  #17
dknj's Avatar
makes sense, thanks all.
Old 06-06-2014, 04:11 PM
  #18
rjfjr's Avatar
Originally Posted by HitchAnything
The Class 1 trailer hitch is the only option for a 2006 Audi A6. Curt manufacturing makes a good class I for the A6, which can be found here. This hitch can still tow up to 2,000 pounds of gross trailer weight (GTW), so it's no slouch. We also sell trailer hitch kits which include both the hitch and the applicable wiring harness.
Happy towing!
How about for an '08 S6? is there a bolt-in part # i can reference on your site?
Old 06-12-2014, 11:55 PM
  #19
daredevil1's Avatar
This is what I've had on my 06 for 2 years:
Wiring:
Amazon.com: Hopkins 46365 Short Proof Power Converter: Automotive Amazon.com: Hopkins 46365 Short Proof Power Converter: Automotive
Hitch
http://www.etrailer.com/Trailer-Hitc...eid=2006300947
shaggymatt
10
10-11-2016 09:32 AM
Hprd
02-02-2016 07:04 AM
Olatunde Etiko
Q7 MK 1 Discussion
09-20-2015 08:20 PM
AlllRoad
09-15-2015 12:51 PM
Dale Kirstein
05-30-1999 10:52 AM
Quick Reply: hitch on '06 A6
