How badly am I screwed? P0021
Old 05-15-2014, 10:55 AM
roylok's Avatar
Default How badly am I screwed? P0021 - (issue solved read the solution below)
This doesn't sound good at all, at a stoplight I felt a slight vibration and CEL flashed than went away. I was very close to home and when I stopped I could hear the engine misfiring at idle. VCDS confirmed it misfire on cylinders 6 & 8
Bank 2: Camshaft A (Intake)
P0021 - 004 - Retard Setpoint not Reached (Over-Advanced) - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 199756 km
Time Indication: 0
Date: 2014.05.14
Time: 18:50:03
Freeze Frame:
RPM: 2147 /min
Load: 51.7 %
Speed: 27.0 km/h
Temperature: 36.0°C
Temperature: 17.0°C
Absolute Pres.: 980.0 mbar
Voltage: 14.351 V
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 199757 km
Time Indication: 0
Date: 2014.05.14
Time: 18:52:03
Freeze Frame:
RPM: 1085 /min
Load: 21.2 %
Speed: 34.0 km/h
Temperature: 52.0°C
Temperature: 17.0°C
Voltage: 13.970 V
000776 - Cylinder 8
P0308 - 001 - Misfire Detected - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 199757 km
Time Indication: 0
Date: 2014.05.14
Time: 18:52:03
Freeze Frame:
RPM: 1085 /min
Load: 21.2 %
Speed: 34.0 km/h
Temperature: 52.0°C
Temperature: 17.0°C
Voltage: 13.970 V
000774 - Cylinder 6
P0306 - 001 - Misfire Detected - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 199757 km
Time Indication: 0
Date: 2014.05.14
Time: 18:53:32
Freeze Frame:
RPM: 1849 /min
Load: 38.0 %
Speed: 21.0 km/h
Temperature: 62.0°C
Temperature: 18.0°C
Voltage: 14.351 V
Measuring block 93 reads:
13:28:36 Group 093
-1.0°KW Idle Stabilization
0.0°KW Idle Stabilization
-3.0°KW Idle Stabilization
That's not bad is it?I did redline the engine earlier, and if I caused it I want to shoot myself in the dick! How bad is it? Help please
Old 05-15-2014, 11:54 AM
IMD
IMD's Avatar
Hi. Sorry to hear that. By elsa to P0021 u have to do this to check if the "Camshaft Adjustment Valve 2 -N208" is working properly.for that u need multimeter to check the voltage and resistance. let me copy them and attach the pics
Camshaft Adjustment Valve, Checking
This procedure is used to check the Camshaft Adjustment Valves -N205 and N208-.
Special tools and workshop equipment required
t Multimeter -V.A.G 1526 A- or equivalent.
t Voltage Tester -VAG1527B- or equivalent.
t Adapter Cable (121-Point) -VAG1598/31-.
t Connector Test Set -VAG1594C-.
Test requirements
l Fuse for valve for camshaft adjustment OK. → Wiring diagrams, Troubleshooting & Component locations.
l Ignition switched off.
l The Fuel Pump (FP) Relay -J17- OK. → Chapter.
Note
Voltage for camshaft adjustment solenoid valves is supplied via the Motronic Engine Control Module (ECM) Power Supply Relay -J271-.
Test sequence
Cylinder bank 1 (right):
– Disconnect the electrical connector -2- from the Camshaft Adjustment Valve 1 -N205-.
A24-10017
Cylinder bank 2 (left):
– Remove the screw -arrow- retaining the coolant reservoir.
A10-1522
– Disconnect the electrical connector from Engine Coolant Level (ECL) Warning Switch -F66- at the bottom of the coolant reservoir and set aside the coolant reservoir with the coolant hoses -1- and -2- connected.
– Disconnect the electrical connector -3- from the Camshaft Adjustment Valve 2 -N208-.
A24-10046
Checking internal resistance
– Using the Multimeter -V.A.G 1526 A- or equivalent, check the following wiring connections for open circuit.
Specified value: 8 to 13 Ω.
If the specified value is not obtained:
– Replace the faulty Camshaft Adjustment Valve.
If specified value is obtained:
Checking voltage supply
A96-0342
– Using the Voltage Tester -VAG1527B- or equivalent, check the following wiring connection for voltage.
A24-0331
Harness connector
Terminal Measure to
1 Engine Ground (GND)
– Operate the starter briefly:
The LED must light up.
– Switch the ignition off.
If the LED does not light up:
– Check the wiring connection from terminal 1 of the electrical harness connector via fuse to the Motronic Engine Control Module (ECM) Power Supply Relay -J271- terminal 2 for an open circuit:
Specified value: Wire resistance max 1.5 Ω.
– Check the wiring for a short circuit to Battery positive (+) or an open circuit.
– If necessary, repair the wiring connection.
If the LED lights up.
Checking activation
– Connect the Adapter Cable (121-Point) -VAG1598/31- to the wiring harness of the Engine Control Module (ECM) -J623- ; the ECM is not connected. → Chapter.
– Using the Adapter Cable (121-Point) -VAG1598/31- and Multimeter -V.A.G 1526 A- or equivalent, check the following wiring connections for an open circuit.
l Camshaft Adjustment Valve 1 -N205- (bank 1).
A24-0331
Harness connector
Terminal Test box
Socket
2 115
l Camshaft Adjustment Valve 2 -N208- (bank 2).
Harness connector
Terminal Test box
Socket
2 120
If the specification is not obtained:
If no malfunctions are found in the wiring:
– Replace the Engine Control Module (ECM) -J623-. → Chapter.
If no malfunctions are detected:
– Replace mechanical camshaft adjuster. → Engine Mechanical; Rep. Gr.15.
Assembly is performed in the reverse order of removal, note the following:
Final procedures
After repair work, the following work steps must be performed in the mentioned sequence:
1 - Check the DTC memory. → Chapter.
2 - If necessary, erase the DTC memory. → Chapter.
3 - If the DTC memory was erased, generate readiness code. → Chapter.
– End diagnosis and switch the ignition off.
Old 05-15-2014, 11:58 AM
IMD
IMD's Avatar
Default PICS
Good luck
Old 05-15-2014, 01:51 PM
roylok's Avatar
Thanks IMD, I removed the coolant reservoir and it looks nothing like the picture. I only see 2 connectors not 4.
Old 05-15-2014, 02:15 PM
IMD
IMD's Avatar
give me the year and model of your audi ill try to pull info
this is from mine 2006 4.2
Old 05-15-2014, 02:20 PM
roylok's Avatar
It's 2007 4.2 Sorry about that, I should have mentioned at the beginning of the post.
Old 05-15-2014, 02:29 PM
IMD
IMD's Avatar
gimme few sec
Old 05-15-2014, 02:40 PM
IMD
IMD's Avatar
Camshaft Adjustment Valve 1 N205 and Camshaft Adjustment Valve 1 (Exhaust) N318, Checking
The following procedure is used to diagnose both Camshaft Adjustment Valve 1 -N205- and Camshaft Adjustment Valve 1 (exhaust) -N318-
t Multimeter.
t Wiring diagram.
Test requirements
l The Camshaft Adjustment Valve 1 -N205-and Camshaft Adjustment Valve 1 (exhaust) -N318- fuses OK.
l Engine Control Module (ECM) Power Supply Relay -J271- OK.
l Battery voltage at least 12.5 volts.
l All electrical consumers such as, lights and rear window defroster, switched off.
l Vehicles with automatic transmission, shift selector lever into position “P” or “N”.
l A/C switched off.
l Ground (GND) connections between engine/transmission/chassis OK.
Test procedure
– Perform a preliminary check to verify the customers complaint. Refer to → Chapter „Preliminary Check“
Start diagnosis
Procedure
– Remove the engine cover with air filter .
A97-0973
– Disconnect Camshaft Adjustment Valve 1 -N205- electrical harness connector -1- or Camshaft Adjustment Valve 1 (exhaust) -N318-.
A15-10200
– Using a Multimeter, check the Camshaft Adjustment Valve 1 -N205- or Camshaft Adjustment Valve 1 (exhaust) -N318- for resistance.
– Measure pin 1 & pin 2 of the component.
Specified value: 5.0 to 8.0 Ω (at approx. 20° C)
If the specified value was not obtained:
– Replace the Camshaft Adjustment Valve 1 -N205- or Camshaft Adjustment Valve 1 (exhaust) -N318- .
If the specified value was obtained:
Checking voltage
– Switch the ignition on.
– Using a Multimeter, Check the Camshaft Adjustment Valve 1 -N205- or Camshaft Adjustment Valve 1 (exhaust) -N318- electrical harness connector terminal 2 to SA 3 for voltage.
Specified value: battery voltage.
– Check the wiring connection for an open circuit, short circuit to Battery (+) or Ground (GND).
– Check the wiring connection for damage, corrosion, loose or broken terminals.
– If necessary, repair the faulty wiring connection.
Checking wiring
If the manufacturers test box is being used, perform the following step.
– Install the test box.
If the manufacturers test box is not being used, perform the following step.
– Remove the Engine Control Module (ECM) -J623-. Refer to appropriate service manual.
A28-0039
– Using a Multimeter, Check the Camshaft Adjustment Valve 1 -N205- or Camshaft Adjustment Valve 1 (exhaust) -N318- electrical harness connector terminal 1 to the Engine Control Module (ECM) electrical harness connector for an open circuit.
A28-0040
Camshaft Adjustment Valve 1 -N205 -electrical harness
connector terminal Engine Control Module (ECM) electrical harness
connector T60 terminal or
test box socket
1 50
Camshaft Adjustment Valve 1 (exhaust) -N318-electrical harness
test box socket
1 5
Specified value: 1.5 Ω Max.
– Erase the DTC memory. Refer to → Chapter „Diagnostic Mode 04 - Erase DTC Memory“
– Perform a road test to verify repair.
If the DTC does not return:
Repair complete, Generate readiness code. Refer to → Chapter „Readiness Code“.
If the DTC does return and no malfunction is detected in the wiring and the voltage supply was OK:
– Replace the Engine Control Module (ECM) -J623-. Refer to appropriate service manual.
– Assembly is performed in the reverse of the removal.
– Install the engine cover with air filter .
Final procedures
After repair work, the following work steps must be performed in the following sequence:
1 - Check the DTC memory. Refer to → Chapter „Diagnostic Mode 03 - Read DTC Memory“.
2 - If necessary, erase the DTC memory. Refer to → Chapter „Diagnostic Mode 04 - Erase DTC Memory“.
3 - If the DTC memory was erased, generate readiness code. Refer to → Chapter „Readiness Code“.
Old 05-15-2014, 02:42 PM
IMD
IMD's Avatar
Default Pic
HI
Old 05-15-2014, 02:44 PM
IMD
IMD's Avatar
Sorry i make you to take off the coolant reservoir
Quick Reply: How badly am I screwed? P0021
