Last edit by: IB Advertising
- Audi A6 C6 How to Replace Headlight Bulbs<br>Step by step instructions for do-it-yourself repairs.
How to Replace 2008 A6 4.2 Headlight Bulbs
#11
It's not too bad. The PDF gives good instructions but for the left side, you will need to be a contortionist to do it as there is very little space to work. Aligning the bulb is also important - you may end up with high beams instead of low beams. It's like that on mine after I changed it but I do not dare to open it up again.
The control is on the bottom of the headlamp housing and there is only one way that the bulb will fit.
Just loosen up the power steering reservoir and move it to the side you'll have enough room to work with.
#12
Thank You!
This is the procedure for a 3.2. It is probably similar.
http://dl.dropbox.com/u/14739987/C6%...eplacement.pdf
#13
Thank you, but now in need of new door/cover
My one mistake was during the opening of the headlight door/cover on the passenger side. I broke both tabs when pushing down and now my headlight door/cover is fastened to the rest of the headlight assembly with duct tape. I've done some looking to find a replacement headlight door/cover and all I'm able to find is the entire headlight assembly. Does anyone have any suggestions as to where I might find just the door/cover? I can't be the first to have made this mistake.
#14
THANK YOU.
beachcomber
14
07-26-2021 05:08 AM
bballfreak
9
04-14-2019 06:59 PM
