sealing center brake light in avant
Hi,
I have to take out the rear center brake light in my avant. It seems the was some caulk between light and the metal part of the gate to seal off water comming though the gate. The manual did not say anything about replacing the caulk. Do I need to put a bead of household caulk there or just leave as is?
Would it make water leaking under the rear gate lining?
Hi,
I think I saw an extensive DIY on another forum that explained how to remove the rear window trim to get to the light - and even how to re-solder the bad connections.
Did you do it yourself?
I remove the red glass and get to the led. The connector was rotten due to the salt and water on the quebec road in the winter.... I tey to fix it but it was to far away. So I end up by buying a new one....
Did you replace yours due to the read center LED intermittently throwing a code? Seems there is a defect in the C6 Avant center rear LED soldering.
Hi,
Pete K (vegasguy)
07-21-2008 09:52 AM
bdavies
11-25-2003 04:14 PM
velo
05-02-2003 06:19 PM
